CR/XC exhaust question
White Husky
Hello
Could someone help me please to check whether the exhaust that came on my '83 XC500 is suitable?
There's a sticker on the silencer with part number 15-13-393-02 written on by hand. If correct, this seems to correspond to a 1985 CR250 silencer.
Here's a photo of what I have:
The dimensions are:
  • 14"3/8 long from tip to tip
  • The input bore is 1"3/8
  • The output end is 2" wide and 3" tall
  • The centre of the mounting bracket hole is 10" from the front
Would someone with a CR500 mind measuring their silencer to see if it's similar please?
I'm trying to quieten the bike down, so figure that if a 500 CR silencer is bigger it should be quieter. I may also buy a spark arrestor type silencer for non-closed-circuit use, so if anyone has any tips on what fits I'd appreciate them, for example has anyone tried an FMF universal TurbineCore or the SuperTrapp Univeresal Quiet? Or anything else?
Thanks
Lucien
Go to pvpcycles.com they have FMF silencers for vintage Husky's. If you look in the photo section it shows Husky's with them on.
I've used brand new FMF universal spark arrestors/silencers on all of my Huskies and other vintage bikes -- and there's no real difference -- they're still LOUD!!! Especially the Huskies and Yamahas...My LOUD theory comes down to the fact that these old bikes have cylinders heads that are NOT insulated like modern 2 strokes, therefore you get more resonance, more mechanical noise, and subsequently more Db from the exhaust. It's just a theory. I'm almost embarrassed to start my vintage bikes in the neighborhood. Even though theyre not as loud as the Harleys,, cruisers, and offroad thumpers they're still loud --especially my Husky 400's. I truly don't think it's really going to quiet it down alot, but with a FMF, PC, or Answer Silencer you won't have to worry about the silencer getting coked up with carbon and losing power like you do with the OEM K-type silencers
Thanks Frog - had a look and they're there. I can buy in UK for £100. A lot of money to spend if they don't muffle things down!
Skoalman;58832 said:
I've used brand new FMF universal spark arrestors/silencers on all of my Huskies ...they're still LOUD!!! . . . but with a FMF, PC, or Answer Silencer you won't have to worry about the silencer getting coked up with carbon and losing power like you do with the OEM K-type silencers
Thanks Skoalman. I was going to order a universal FMF. Have to think twice now. I was also tempted to get a OEM spark arrestor. If it's going to be quiet then I don't mind regular cleaning and repacking, as it's for occasional use.
I've also got a lead on a European company called DEP who used to make pipes for the Huskies back in the day. Apparently they still have the jigs and can make me a new tail pipe. Waiting to hear back on costing! Ouch. Won't be cheap.
Pro-Circuit are also having a look through their stock for me to see if any of their silencers will fit the measurements I gave them. I don't think they'll be quiet though, but hopefully quieter than a 250 Husky pipe (assuming that's what mine is).
Any more views or tips anyone?
Cheers
Lucien
White Husky;58780 said:
Hello
The dimensions are:
Thanks
Lucien
Hi Lucien,
I can measure my '85 500 CR silencer tomorrow and let you know.
Stu
Cheers
Lucien
While I was at work it came to me -- the Dirtbike snorkle -- here's your answer for quieter times!!
Check this out Lucien:
www.thedbsnorkel.com
Wicked. Is it good for river crossings too?
I'm gonna hunt one down. Will keep you posted. Thanks for the tip Skoalman ... and sorry to wreck your day!
Cheers
Lucien
Cheers
Lucien
You didn't wreck my day man...Shoot, I'm above ground brotha!!! Glad I could help!
silencer measurements
Lucien,
The silencer on my 84 500CR is 18" total length, 15" silencer
part. 3" long tube that attaches to pipe. It's 10-1/4 " from pipe
inlet to mounting bolt center.
Hope that helps :)
John
Measurements
Hi Lucien,
My '85 500CR Silencer measures as follows:-
1. Tip to tip: 18 and 3/8
2. Input bore 1 1/2
3. Output end: 3 High x 2 wide
4. Bracket to Mounting from front: 10
Just slightly different than yours...
Unlike John's mine doesn't have any other bits between it and the end of the exhaust... slips straight over.
Hope this helps.
Stu
ruwfo;59024 said:
The silencer on my 84 500CR is 18" total length, 15" silencer part. 3" long tube that attaches to pipe. It's 10-1/4 " from pipe inlet to mounting bolt center.
Thanks John. Fairly conclusive then I think my silencer must be off a CR250. I think I'm gonna try the snorkel that Skoalman mentioned. Looks kind of weird, but if it cuts the noise then that's great for me. Further research also reveals that it's worth insulating the airbox (induction) and wrapping the expansion chamber (detonation). Hmm.
2. Input bore 1 1/2
Thanks Stu. To get through its MOT mine had to have one of those db killers inserted in the end of the silencer, but it was literally like reducing the output bore to 5mm whcih of course increases the back-pressure which on a 2T is not ideal. Anyway it was causing all sorts of s%^* to spu out of the header pipe. To be honest I know the crank seals are not the strongest on these engines so I don't want to blow them. I'm sure I'm being paranoid.
I've emailed db-snorkel. I'll probably try other options also to find the best, so I'm still open to ideas. Funny, when I was 25 I didn't care about noise. Now all of a sudden I find myself considerate. Hmmm
