125-200cc cr125 help
Discussion in '2 Stroke' started by mark animal100, Jul 28, 2013.
  1. mark animal100 Husqvarna
    wre125
    cr125
    hi I have a cr125 well when I select neutral when it cold it ok but once hot I just cant find neutral I goes 1st or 2nd gear am guessin clutch drag any idears ?I realy hate riding a bike with no neutral
  2. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    Just make sure you have the correct free play at the perch I think 3mm if you pull on the cable housing.
    Does it help if you rock the bike back and forth a little?
  3. mark animal100 Husqvarna
    wre125
    cr125
    no ive tried that ive cheaked clutch all good ive tried 5w40 oil full senthetic and 10w40 and 15w40 nothing is helping its some sort of clutch drag but cant fix it
  4. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    Have you checked out the friction discs or the clutch assembly? Its really easy to do.
    What year cr 125?
    I'd check the basket for bad notching, or maybe a broken friction plate.
    I'm not sure if it would lead to the problem your having but I always check the easier stuff first. Especially with seemingly transmission issues.
  5. mark animal100 Husqvarna
    wre125
    cr125
    yer all good its done this since new n I also own a wre125 2013model for my rd bike and its just the same fine when cold until hot then neutral just gets realy difficult to find ,I can only get neutral to select if I change in to neutral while moving at about 5mph other than that no joy both husky r the same.. am guessing a bad choice of bike I had a Yamaha wr125 and should of keept it the shop says to me that's how they are but surley u should get neutral
