125-200cc cr125 top end rebuild kit?
Discussion in '2 Stroke' started by melias24, Apr 30, 2018.
  1. melias24 Husqvarna
    Whitsundays region, Queensland, Australia
    2013 CR125
    Hey everyone,
    Been in-active quiet a while, and wanting to get back into riding, can someone point me in the right direction of sourcing a top end rebuild kit with gaskets for my 2013 CR125?
    Also, my rear shock is also quiet sagged. Would winding up the coil or adding air improve this?
    ~Elias
  2. rancher1 Husqvarna
    WA
    The shock probably need a rebuild and it contains nitrogen not air. You could try adding nitrogen since it has been sitting it may fix it and it isn't to expensive.
    melias24 likes this.
  3. Down Under XC Husqvarna
    Melbourne, Australia
    XC250 83', WR250 87','XC150 10
    WR165 10, 83 KDX 250,
    Hi Elias,
    You may be able to go OEM, thru Husqvarna but watch out for price. Wossner also do a complete range of aftermarket gear for top end rebuild, they are as good or better than OEM. piston rings, little end and gudgeon plus circlips and gasket set. You will need to pull yours down and ascertain piston size, usually marks on top of piston signify size via a,b,c,d. see bikes and bits website.
    re rear suspension.
    go to kroozetune website and look at what they recommend for setting sag. if you are over 80-90kg chances are you are too heavy for standard spring which I think is a 4.8 look on this site for what standard is although US bikes may be different.
    caged
  4. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    Wossner rebuild kit is good quality. Just rebuilt mine and everything fit real well. A little hard to find, but I contacted them directly and they were very helpful
    melias24 and NCSteve like this.
  5. melias24 Husqvarna
    2013 CR125
    Cheers for your help. Should be able to obtain the piston size by pulling the head off and looking on top of the piston?
    Also, i'm 79kg, i'll go to that website and check out details about setting sag. Cheers for your help!
  6. melias24 Husqvarna
    2013 CR125
    Interesting, i thought they'd be air. Thanks for the heads up!
  7. melias24 Husqvarna
    2013 CR125
    Thanks i'll check it out! Wossner seems to be the go. How much did you pay for the kit? Gaskets etc everything included?
  8. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    Nitrogen is best but you can uuse air, though it's probably the spring. The bladder charge has nothing to do with suspending the bike and I'm 65kg and had to go heavier on the back, lighter on the front. They're not well balanced from the factory
  9. melias24 Husqvarna
    2013 CR125
    Yeah it has always been a big sagged in the back from the day i got it with only 20 hours on it
  10. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    there is a basic sag adjustment for these, do you have the owners manual to check the baseline?
    if the adjuster is way past half way you will need a stiffer spring
    if it way less than half way you should get a lighter spring
    this is based off the factory recommended sag check
  11. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    image.jpg I've been watching this one for a while. Has everything you need for $152 delivered! Check all ya linkage/shock/swingarm bearings are ok & greased then yeah get the right weight spring & shock oil/gas change
  12. rancher1 Husqvarna
    WA
    I thought the engine run was from 1998-2014, but then again we did not receive 1997 models in the US.
  13. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    I think you're right it'll just be a stuff up on their behalf. Hard to get good info on Italian Huskies.
  14. melias24 Husqvarna
    2013 CR125
    Do you think that piston would be of good enough quality?
    Cheers
  15. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    I'm running one!
  16. melias24 Husqvarna
    2013 CR125
    Sweet! Guess rip my head off a measure what size piston i need?
  17. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    i used Mitaka/Aoki Pistons for Years with only good results.
    u can also run a Honda CR125 from the mid 90s or a yz125 05- but for the yz piston the cyl.head needs to be machined.
  18. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    is your bike still running? :confused:
    NCSteve likes this.
  19. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    No! :lol:
    shawbagga likes this.
  20. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Haha ya pair of dicks. Incidentally it died the other day but haven't washed it to look for problem yet. I'm suspecting ignition or stator but hoping just a wire
