125-200cc cr125 vibration
Discussion in '2 Stroke' started by mark animal100, Aug 19, 2013.
  1. mark animal100 Husqvarna
    wre125
    cr125
    is it normal to have vibration on foot pegs n handle bars am new to husky n 2 strokes all ways had 4strokes
  2. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I don't notice much - check all the engine bolts
  3. 72racerx Husqvarna
    Melbourne, Australia
    13 WR144
    01 VFR800
    2 bangers do tend to vibe a bit more than 4 strokes. But as rockdancer has mentioned check all the engine mount bolts, if everything is tight go hard !!! You will get used to it.
  4. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    Compared to my 09 300 the 150 has NO vibration. Check all bolts, but I do not think mine has any.
  5. venturini Husqvarna
    USA
    '15 TC 250 '13 CR 150 '11 TE 310
    '12 KTM 250 XC
    Are you riding it really high in the RPMs? My nephew usually complains about his 65 vibrating a lot when he hasn't ridden for a while but when I ask his what gear he was in on the straight a way, he'll say "2nd" I tell him "once it's screamin' then shift buddy---the vibes will go down and you'll go faster"
  6. husky195 Husqvarna
    NSW Australia
    2013 Wr165 2013 wr125
    1994 TM250 1995 TM125
    how many hours are on your bike? if you have checked that everything is tight then it may be your main bearings. mine usually last between 40-50 hours
  7. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    My 04 cr125 has nearly 200 hrs on it with the same main bearings and crank.
    You can get handlebar inserts to deaden the vibration.
  8. AWM Husqvarna
    Your Moms house
    WR150
    Orange
    2strokes vib alot compared to a 4 stroke.
    If theres nothing loose theres nothing to sweat.
    When the vibs get to the point of discomfort,,,twist the throdle more and you wont notice.
    Jersey Woods and Motosportz like this.
  9. Jersey Woods I live to ride !
    Monmouth County NJ
    2011 WR 150 2018 TE 150
    KTM EXC 250 F Honda 300 ATV
    Ditto to that ^^^^^^^^^^^^^^^^^
    If mine vibrates, I never noticed it. And I ride in everything the New Jersey Pine Barons can throw at it. :cheers:
  10. 72racerx Husqvarna
    13 WR144
    01 VFR800
    I forgot to mention in my earlier post, do yourself a favour and pull off the magneto cover and give the flywheel a bit of tug up and down and backwards and forwards to see if there is any movement. If there is your main (crank) bearings are probably shot. This would probably feel like a deep rumbling vibration when the engine is running.
    husky195 likes this.
