125-200cc CR150 Fork Shim Stack
Discussion in '2 Stroke' started by Travis616, Mar 21, 2017.
  1. Travis616 Husqvarna
    Ontario, Canada
    2021 TC125
    2006 Honda CR125/134 build
    I'm wondering if anyone knows what the stock compression shim stack is in the KYB forks on my '11 CR150? I was going to revalve them the same as a YZ125 but didn't know if/what shims I would need - hoping that it just needs some removed
  2. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    This is what came out of stock set of TXC kyb cc/sss forks I put on my WR.
    Base
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    32x0.1
    30x0.1
    28x0.1
    26x0.1
    24x0.1
    22x0.1
    20x0.1
    18x0.1
    16x0.1
    15x0.1
    14x0.25
    18x0.3
    18x0.3
    18x0.3
    20x1.6
    (bleed stack)
    11x0.25
    11x0.25
    22x0.1
    22x0.1
    22x0.1
    Comp
    20x0.1
    20x0.1
    20x0.1
    20x0.1
    17x0.1
    17x0.1
    17x0.1
    11x0.25
    11x0.25
    17x0.3
    17x0.3
    17x0.3
    Float = 0
    Reb
    20x0.1
    20x0.1
    20x0.1
    20x0.1
    13x0.1
    18x0.1
    16x0.1
    14x0.1
    12x0.1
    10x0.25
  3. Travis616 Husqvarna
    Ontario, Canada
    2021 TC125
    Thanks, mine are likely close to that, starts off much the same as the yz's but then take off
  4. Travis616 Husqvarna
    Ontario, Canada
    2021 TC125
    Took my forks apart yesterday. Doesn't look like it's ever been re-valved, nut was still staked on the base valve assembly. Thought it was weird that there was no bleed stack - two 11 X .15 shims then a heavy washer. I ended up taking out two of the 32 X .11 face shims so I'm not sure how much difference that will make
