125-200cc Cr165 missing on top
Discussion in '2 Stroke' started by Chef, Nov 21, 2016.
  1. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    01 Husaberg FE650, 07 BMW 650 Dakar
    My 08 cr165 ran like a scalded cat all season. On my last ride the bike wouldn't come on to the pipe near as hard and was missing at the top of the revs. It ran fine on the bottom and mid and started just like it always had. I changed out the plug and had the same results. Running a lectron and the wb pipe. The plug wasn't fouled and looked nicely brown although perhaps a little on the lean side. I richened up the pj but it made no difference. The guy behind me said the bike smelled richer. I checked for air leaks around the carb boot with starting fluid and it seems all good. Open to suggestions on where to go with this.
    Thanks in advance
    K
  2. wallybean Mini-Sponsor
    Montana
    Check your ground at the coil. Make sure it is tight, clean, and not cracked. Also when the power jet is too rich it will miss like that but I don't know why it would change.
  3. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Gotta check all the basics first: fuel flow/petcock screen; ^ ground, plug wire/cap; compression! filter; muffler. Be interested in what you find out. :cheers:
    Trenchcoat85 and wallybean like this.
  4. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    ...after Steve's excellent checklist, the next level would be things like the power valve, reeds, loose jet, flywheel, rag (or mouse) in the airbox, etc.
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    compression check for sure... lower compression will cause richer running and less pull when on the pipe.
  6. JAM Husqvarna
    South Carolina
    2012 WR144
    2017 Beta Xtrainer 300
    Ditto on the reeds- they flap a lot and are overlooked.
  7. Travis616 Husqvarna
    Ontario, Canada
    2021 TC125
    2006 Honda CR125/134 build
    I have found that bad reeds will usually make it hard to start and run strange at low rpm but the high the revs, the better it runs. Since we don't have penny's in Canada anymore my 2 cents are now free. Lol
    JAM likes this.
  8. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    Thanks for the suggestions. Well, I finally found a bit of time to put in to this. A kitchen renovation and life seemed to have got in the way. I found a connector on the coil that wasn't tight, that isn't to say it was loose but the connector could move on the bolt. Reeds check out good. Unfortunately it seems winter has arrived here so I now have the bike in the basement to do winter maintenance and repairs. I'll keep you posted on what I find.
    Thanks again
  9. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
  10. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
  11. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Trenchcoat85 likes this.
  12. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    The difference between a professional mechanic and a backyard mechanic is troubleshooting. I called it on the first page :D
    I posted it because I thought Chef might remember it, and he may have a similar problem. He's on that forum too.
    Oldscool likes this.
