Cracked case 510LC
Discussion in 'Vintage/Left Kickers' started by Krudd, May 5, 2019.
  1. Krudd Husqvarna
    Sweden
    89A 510TE, 89B 510TE
    '81 Yamaha XT500
    Pic shows inside of a liquid cooled 510 left case half.
    Would you say that crack is reason enough to scrap it?
    It goes through to the other side as well.
  2. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    I'd get it welded ?
  3. fran...k. Husqvarna
    eastern ct
    That is hard to tell what I am looking at Can you put a picture zoomed out to show the whole case is visible. I would say that is basically scrap. Cast aluminum doesn't weld like aircraft grade.
  4. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    It's at the hole for the shifter mechanism/lever axle.
    Im thinking it's difficult to get it good enough since I reckon the force from the secondary shaft pushes there.
  5. fran...k. Husqvarna
    eastern ct
    That picture most likely is an 85 and earlier 250 two stroke. I see it really was inside the case. Most problems to put a bike or engine to parts probably are not this issue. The one at the swingarm pivot more so on the other side for case issues.
  6. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Yup, it's from a '87 2T manual. Didn't have any good 4T pics (I'm at work..).
    I've not much too lose trying to get it welded as it's an extra pair of cases I've got. Still, always nice with spares!
  7. fran...k. Husqvarna
    eastern ct
    The manuals do tend to use pictures from years prior. Rather significantly different in the later auto bike. Perhaps that damage could occur forcing improperly aligned things together.
  8. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    The damage is most likely from a thrown cam chain wrecking havoc in the clutch case.
