250-500cc Cracked Jug !! AAAAHHHHHHH!! 02cr250
Discussion in '2 Stroke' started by chris anders, Nov 21, 2015.
  1. chris anders Husqvarna
    2002 CR250 , 2002 CR125
    2003 Suzuki RM250
    Well it seems ive solved my "falls off of an idle and dies/ air leak mystery- Damn,was just finishing her face lift too. Time to drop a couple more $$ i guess. anybody have a spare jug for a cr250 laying around ?
    crack in mine is fairly small-wonder if repair is possible? any thoughts??
  2. PawPaw Husqvarna
    2013 TC 449
    Honda Crf450R + old CB750
    You should be able to get it welded, if it does not go into the water jacket. If you do, then I would also have the cylinder base recut to be sure it is flat after the welding.
    Paw Paw
  3. guscycle Husqvarna
    Florida
    '99 Husky CR250, '07 Husky WR125,
    '10 Husky SMR450, '98 Husky Scooter
    Millennium Technologies can fix that ...had a customer with a '89 Honda CR250 that completely cracked thru worse than yours...look brand new when they got done with it...
  4. Claybilly17 Husqvarna
    Ohio
    2000 WR250
    2009 KTM 450 SXF
    That looks like an easy fix for an experienced welder.
  5. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    halls has one sombuddy had a link to it posted up here a few days ago
  6. Big Timmy Husqvarna
    (South Eastern) AZ.
    This can be fixed. For now just wipe some silicone over the crack with a finger to seal it and keep diagnosing the idle issue. It certainly can be welded.
    I had a Suzuki 500 quad many years ago that was ported so far for flat track racing, it cracked like that at the flats for the base studs on both sides and into the Reed cage inlet area of the casting just like that.
    To repair it properly, It must be burred open with a carbide bit in a die grinder and welded while it's bolted down to a flat fixture base plate though. Which does make it difficult to weld where the studs and nuts are.
    If you don't do this it will pull the base stud lugs up while welding and re-cutting the base gasket surface flat again on a lathe can change the port timing and TDC deck surface clearance enough that it will detonate and have engine problems. If the head isn't re-chambered.
    My 2 cents.
    I'm sure the shop "Millennium Technologies" mentioned knows what they are doing though.
  7. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    DONT KNOW ABOUT JUGS BUT A PLACE CALLED RACERS TOY STORE DOZE CASES WITH SIMILAR ISSUES
  8. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I have a 01 WR250 jug going cheap
  9. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Don't put silicone on it if your getting it welded that shit makes inclusions in the ally, depending in how well they cut/ clean the crack.
    The real question is why did it crack there are your base bolts to tight or your jug warped in the firstplace?
    jmetteer, Big Timmy and ohmygewd like this.
  10. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Is it poss a cracked or bent frame could cause this crack?
  11. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Besides what Big Timmy said, which is accurate, you also stand the chance of making the cylinder out of round when you weld it. I say weld what you can get to while it's still bolted to the engine and then finish it on the bench. Then dial bore the cylinder and if it's out of round then scrap it since you will have more tied up in it on a re-plate and machining than it's worth. If you can find a good cylinder at a fair price it would probably be the better way to go.
  12. Big Timmy Husqvarna
    (South Eastern) AZ.
    Silicone is so easy to remove. If I was welding this I would burr it to daylight so any silicone having been wiped onto it temporarily to sort your lean idle issue, wouldn't exist anyway after back cutting it for a full pen weld and then I would grind the inside smooth after welding it too.
    Taking in consideration, as Doug says, Its a plated Nikasil bore and it's more vulnerable to warpage from welding. This amount of heat is enough to make it out of round most likely.
    Even if welded as much as can be reached while bolted down to the cases.
    The taller studs and nuts are in the way. That would not be the case if bolted to a fixture plate as the bolts could have the heads cut down and bolted onto that base fixture plate in the opposite direction to allow clearance to weld it but this would be only as a last resort.
    I personally would get another usable, or just purchase a new cylinder altogether. This would be cheaper than having to go down the route to repair it back to a usable condition.
    juicypips likes this.
  13. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Jb weld that sucker n run it til it separates from rest of the donk!
    steadydirt likes this.
  14. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    sounds like a good way to blow it up.
  15. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Possibly but I'd be more confident in metal putty than sikaflex! Do it on bike, dremel out a bit along crack for it to adhere to. Cylinder is knackered really anyway so if wanted to try get bit more life outa it could try. He'll be buying new piston kit regardless.
    ohmygewd likes this.
  16. gwynfryn Husqvarna
    2009 wr250
    I vote for silicone, but to make it a long term solution duct tape it down. Thats right, over the head and right around the frame rails, around six times will be right.
    Thank me later.
    Big Timmy and shawbagga like this.
  17. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    You guys are starting to scare me.
  18. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Bush mechanics! :)
    I'd run it with some sort of sealant(I'd have thought metal putty but silicone if yas reckon is better-both pretty strong id jus worry bout heat/fuel with the silicone) while waitin to buy/find a whole new jug. Probly wouldn't be doin any extreme rides into the desert or deep woods though
    Macgyver woulda jus used some gum on that thing & still won the GNCC while diffusing a bomb.
    steadydirt and Big Timmy like this.
  19. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    You guys are bodging bastards if ya gunna run it till it grenades then use gorilla tape once round the frame n head really is overkill with that, and pu adhesive tiger seal job jobbed then worry when your 20k into your ride and have a seperated cylinder and a snapped con rod.
    Or you could just buy a replacment cylinder an stop any more unwanted costs.
    Motosportz likes this.
  20. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Jus carry an extra roll of duct tape n a couple of paddle pop sticks to splint the rod. Ez. :)
    Motosportz and gwynfryn like this.
