crank case breather pipe correct position
Discussion in 'Vintage/Left Kickers' started by patgas, May 19, 2010.
  1. patgas Husqvarna
    dolgellau/ wales
    does any one know the correct termination for the crank case breather pipe on 79 or 390,wasnt any on mine so not sure how long should be ect and what holds it if anything cheers(oil filler cap)
  2. patgas Husqvarna
    dolgellau/ wales
    come on guys
    surely someone must know where it terminates :confused:
  3. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Tube (vent hose) sticks up & tie wrap it to the frame, tube fits in the cap end fairly tightly, that's all.
    Husky John
  4. subarumy98 Husqvarna
    Australia
    1983 500XC
    Very good question, not sure of the official answer, but here's what I have done:
    1. Up along the "B" frame rail, behind the pipe, and into the large open tube on the frame below the seat.
    2. Up the "B" frame rail, and curl over underneath the airbox, and down the "B" frame rail on the other side.
    I am hesitant to simply go up and terminate vertically - as then stuff can drip straight in...
