crank case pressure question
Discussion in '4 Stroke' started by Last Lap, Feb 27, 2010.
  1. Last Lap Husqvarna
    West Creek, NJ
    I just finished changing my oil on my 310. I started it will the fill plug out and noticed alot of pressuer blowing out of hole. I removed the valve cover breather hose and it did not reduce the pressure comming from the oil fill hole. I rechecked my valve adjustment and they were fine. My question is it this normal or do I have ring or valve issue? Thanks.
    Jeff
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    For one thing, your clutch basket is spinning very close to that opening, so you probably are getting a little "wind storm" off of that.:D I'm surprised that oil didn't come splattering out of the filler too.
  3. kleemann Husqvarna
    Colorado
    Lots of reciprocating bits inside the engine down low near the level hole. About the only way to stop that is to stop the bike ;)
  4. Last Lap Husqvarna
    West Creek, NJ
    Oil was spitting out. I started bike with the plug in and the turn it out and when it got to the last thread it popped out from the pressure. The bike runs fine so maybe it's normal from the spinning clutch. Thanks
  5. Up-tite Husqvarna
    Is your vent hose from rocker cover pinched? Later George
