250-500cc Crankcase breather pipe 2009 wr 300
Discussion in '2 Stroke' started by Bond_yzf, Jan 15, 2012.
  1. Bond_yzf Husqvarna
    After some trails today I noticed some White liquid coming from what I believe to be the crankcase breather (small pipe coming from the cases just under the carb) so I opened up the gearbox oil filler plug and had a look inside with a torch and it looks like the gearbox oil is White, I changed the gearbox oil yesterday so it ain't old.
    I've checked the coolant and it doesn't seem to have lost any
    Any ideas ?
  2. Bond_yzf Husqvarna
    just a thought would that breather suck in water ? i went through a deepish puddle todat pretty fast enough to cover the engine im just wondering if that breather would have sucked water into the gearbox ??
  3. dirt-dude Husqvarna
    Pa.
    Yes. If you ride wet areas relocate trans. and carb vents up to airbox.
  4. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    +1 a must do! top 2 upward facing carb breathers & c/case breather. just make sure you bend em back so theyre facing downwards so water doesnt get in. wont happen again & bike wont die in water crossings either. flush tranny coupla times n all good
  5. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    yep in deep water it cools the air volume in the case and sucks water
  6. Bond_yzf Husqvarna
    cheers for the help guys
