125-200cc crankcase gasket
Discussion in '2 Stroke' started by Husky1502011, Nov 12, 2014.
  1. Husky1502011 Husqvarna
    Qc , Canada
    Hi i have a cr 150 2011 i want to know if i can close the crankcase without the gasket and put threebond 1104 because my new gasket is not perfect fit. Thanks
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    The gasket is made to be a part of the correct tolerances. If by "not a perfect fit", you mean it is the wrong shape that doesn't follow the contours of the case surface, then you need to return it and get the correctly shaped gasket.
    MotoMarc36 likes this.
  3. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Like the Lady said! The transmission endplay could be a problem and the crankshaft could be downright tight. The gasket is probably about .020 which is a huge amount in precision measuring.
