crash damage
Discussion in '610/630' started by 04asphalt, May 23, 2009.
  1. 04asphalt Husqvarna
    SW Michigan
    slight mishap and now I need a new mirror and turn signal.
    I want the folding husky mirrors and LED signals.
    where is the cheapest place for the mirrors?
    do LEDs just plug-in or do they require an extra do-hicky to work?
  2. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    If you look right below your thread (OK my post now) you will see the word tags.
    If you go in there hit "lights" and all the threads will come up for turn signals, head light, etc,etc.
    Or you could punch in "Turn signals" in the search on top same way lots of reading and answers to your questions.
    Good luck.:thumbsup:
  3. 04asphalt Husqvarna
    SW Michigan
    found the info on the blinkers, still not sure if the dash indicator will work with the LEDs unless I use a different relay.:excuseme:
  4. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    I am using the LED relay from Sicass racing and the LED blinkers work fine and the dash display as well.
  5. RumRunner Husqvarna
    Yucaipa, CA (SoCal)
    2007 TE 450
    I have LED's for rear blinkers and stock ones up front (currently) and the indicator light works fine. The blinkers are a little faster than stock, but when I put LED's on the front I will add a new relay to fix that.
  6. 04asphalt Husqvarna
    SW Michigan
    will 08 te610 be the same?
  7. RumRunner Husqvarna
    Yucaipa, CA (SoCal)
    2007 TE 450
    :doh: I didn't notice this was in the 610 section!
    I would think it would be the same. The indicator light should have nothing to do w/how the blinkers behave, well now that I said that they will!
