CRITICAL info for 2010 250 owners!
Discussion in '4 Stroke' started by krieg, Jan 25, 2010.
  1. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    My kickstart lever "locked" itself all the way back against the foot peg tonight while I was trying to start my 2010 TC 250.
    Here's what I found:
    The bolt was on the verge of falling out. I'm not sure how it survived my last ride a few weeks ago.
    I tightened all the case bolts and found SEVERAL loose.
    CHECK them bolts guys! :eek:
  2. CARL REHATCHEK Husqvarna
    Tamaqua, Pa
    2010 TE 250
    I agree.. Two to 3 times went over and over and now they are finding a happy home.. Also keep a eye out on the screw that holds the top on... Seen on of them loosen up and leave its rider kickless..lol
    Chow, Carl
  3. Motosportz CH Sponsor
    And the motor mount bolts. :thumbsup:
  4. buttstock Husqvarna
    NorthWet Oregun
    2013 Husky Strada
    2014 GasGas 300XC, 2002 Rokon
    In the old dazs we use to remove the paint from under the motor mount bolts. A, it makes a better ground . And Loctite everything! I always go over a new bike with and fine tooth comb and check and grease everything.
    Gramps
  5. raisrx251 Husqvarna
    Virginia
    While you are at it check your water pump impeller nut as well. If you don't feel safe doing it have your dealer. I see today where I lost a rear fender bolt on the silencer side where it goes into the air box.
  6. buttstock Husqvarna
    NorthWet Oregun
    2013 Husky Strada
    Good idea. About ready to put Kool-Aid in cooling system and have to drain and flush it. By the way what does it take too make the fan come on? Gramps
  7. john01 Husqvarna
    Powhatan VA
    Good info guys we will be checking over the TC tomorrow when we install the adj. fuel screw, thanks.
  8. krieg Husqvarna
    Matthews, NC
    Many in the past
    Thanks for the tip! Just checked my fender bolts and two were loose. The one in the same place you described would not have made it through another ride! :thumbsup::notworthy:
    Would you mind describing the impeller tightening process with a bit of detail?
  9. raisrx251 Husqvarna
    Virginia
    Yeah they are a strange bolt too, 5mm.
    On the impeller mine was not loose but it was not that tight either. You have to drain your coolant and then on the left hand side of the motor by the valve cover, that is where your water pump lives. It is easier to lay the bike on its right side doing this job. You remove the coolant hose and the allen bolts that hold it onto the side of the motor. The entire assembly will want to come off the bike and there are two paper gaskets so be careful when splitting it open. I do not have a picture of it but if you want me to e-mail me the parts manual just let me know. It is on page 70 in the parts manual and the nut is number 9 on the diagram. I used some brake clean/compressed air on the shaft and nut and made sure it was dry and then added some loc-tite to the nut and tightened it down. Let the bike sit for a hour or two as well would not hurt. There is supposed to be a tech bulletin on this I believe.
  10. Motosportz CH Sponsor
    Let it idle forever, This bike does not seem to get hot. i thought maybe mine did not work until one day doing the EFI and I had it idling for a long time and it finally came on. I have never had it overheat when riding it even on big long hills where a KTM was spewing its coolant.
  11. krieg Husqvarna
    Matthews, NC
    Many in the past
    The fan on my '08 TE 250 never came on during a ride, even in 90+ degree heat while all around me the Pumpkins are puking coolant like drunks on rubbing alcohol. I thought my fan circuit was defective, so finally, I did what Kelly did and along with help from a heat gun, I got it to turn on! My 2010 TC hasn't seen 90+ degrees yet, but she'll idle in the garage for 30+ minutes while hot and not even burp. :notworthy:
  12. aethelred Husqvarna
    UK
    Lets start a check list (feel free to add your issues) 2010 Te250
    1) Front engine mounting bolts came loose
    2) very little grease in linkage
    3) The 5mm side panel screw at rear seam to get cross threaded
  13. Norcalslowpoke Husqvarna
    I had one back out, which toasted the impeller, which caused it to overheat, which blew a head gasket & did some piston damage. $700+ later all fixed. I actually rode for a whole day on fire type roads with no impeller/waterpump. Check that impeller nut!
    Cheers
  14. buttstock Husqvarna
    NorthWet Oregun
    2013 Husky Strada
    Great, one less thing to worry about. Now all I need is a bigger tank?
    Thanks Kelly
  15. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Thanks for heads up, Krieg.
  16. Bykwiz Husqvarna
    Hi guys, I've got a '09 TE-510 and I've had my fan come on lots of times. Not while I am cruising along a gravel road, but working hard in the bush or on a tight technical trail etc... I found it hard to see if it was on or not (black fan blades in black housing etc) so I used a paint stick and put a little yellow line on the fan blades. When I look down now if I see the lines it is off, if I see a yellow blurr it is on. Seems to work. Actually, I may even wire in a little warning light that will come on when fan is on. I seem to like to know this data... Never had an issue and as soon as I get out of the tight stuff and start cruising again it goes off right away.
    Cheers Pete
  17. DougW Husqvarna
    Santa Clarita, CA
    I've notice that any bolt I've removed has had no loctite on them at all. I did notice the other day that the bike was vibrating a lot more than normal and so I checked the engine mounting bolts and they to were way loose. I'm guessing this isn't part of quality control inspections.
