D-908 RR Tire
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by rajobigguy, Sep 7, 2008.
  1. rajobigguy Administrator
    So.Cal.
    Back when I first put tis tire on I really hated it, it was hard to find traction off road, was rough riding and the rear end never felt planted at higher speeds. The only good things I could say for it at the time was that it cornered better on the street with a much more predictable slide in the corners than most DOT knobbies and that the stiff side walls were so heavy you could probably run with no air in it if you had two rim locks.
    Well 1500 miles later I have learned to adapt to the tire a bit and have a few more good things to say about it. It still looks new after 1500 miles, much of which has been hwy. miles and we know how hard that is on knobbies. If you run the tire pressure at about 9 lbs. it does OK in the dirt and loose stuff and so far as confirming that you literally can run it flat, yep you can. I just did quick once over on the bike because I noticed that it was getting kinda squirmy at higher speeds on the hwy. so I thought I would check all the normal thaings like steering head bearings linkage and swing arm bushings ect. and when I got to checking the tire tire pressure the front was a bit low but the back had zero-zip-nada.You wouldn't know it by pushing on the tire, it felt like it might have been overinflated but the gauge doesn't lie. Not only have I been riding with a flat tire I don't even have rims locks and that sucker stayed put. Bottom line is that even though the 908 might not best the best tire so far as traction off road it certainly is one tough tire.
  2. Mike Kay Husqvarna
    California
    I'm a big fan of that tire for big bikes. Compared with the other 'adventure' type tires its hard to beat. Rode one flat thru a scenic chunk of Morocco...:)
