db killer part number?
Discussion in '4 Stroke' started by husky123, Jul 7, 2009.
  1. husky123 Husqvarna
    Leesburg, VA
    I've searched, I swear! My Husky dealer parts girl can't seem to find this "db killer" for my '09 TE510. Would anyone happen to have the P/N so I can try to embarrass her.......again.:thumbsup:
    Thanks!
  2. Droolsport Husqvarna
    Arizona
    Found this
    I looked in the '09 TE310 Parts Catalog and discovered that there is an alternate exhaust diffuser shown (see page 133, part 11, 8000H0827 - Noise reduction device). I called Jeff at Hall's Cycles to see what he could do; Jeff called the alternate part the "db Killer" and said that it was available from Husky (about $63).
  3. husky123 Husqvarna
    Leesburg, VA
    Droolsport, you are the man!:cheers:
  4. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    Don't order the Part number 8000B1546 which is labeled "Noise Reduction" It is equivalent to the spark arrestor in sound- but has no screen. It does have about an inch of tube that goes into the silencer (same ID as the spark arrestor)- but it is not effective at decreasing db compared to the stock Spark arrestor.
    I have that one- and intended to bring my bike from 99.9 db with spark arrestor in to under 96- but this part won't do that- I wanted what Rick Ramsey has here
    The parts fiche is kinda confusing on this issue- who would have thought there was multiple Db Killers 1 that works and 1 that doesn't do much beside inspire modification. I kept putting Ricks part number in Halls online parts# search and it didn't come up-which is partially why I got this one- call them I guess.
    I spose compared to NO insert it is a db killer intended for closed circuit or something... MX or SM
    mine was $50- should have returned it - but the dealer wasn't real motivated so I will weld on some more tube and trim it until I hit 95db-I will live. :cool:
  5. fury1 Husqvarna
    ma.
    just finished mounting up the DB killer insert and will be having it tested this weekend at our local enduro,it sounds much quieter and now the motor makes more noise than the exhaust! not suure what the stock exhaust on the txc250 pushes out,but I dont think it was loud to begin with,but this club is very strict and I probably will change it out before key time!
  6. geastman Husqvarna
    Ontario
    My stock TXC250 registered 95.7db at 5200 rpm with the spark arrester removed. I put the spark arrestor back in for the next organized ride, but they weren't sound testing that day so I can't say what difference it makes.
  7. fury1 Husqvarna
    ma.
    just a follow up my bike tested out at 86 DB at 4500 rpms!! sounds like a sewing machine at idle!!
  8. Jrmobb Husqvarna
    Simi Valley,ca
    Awesome! I will eventually get one. My bike sounds like a tractor compared to my friends ktm 530. His bike purrs
    Did the bike run different from the restriction? is there still a spark arrestor?
  9. fury1 Husqvarna
    ma.
    no spark arrestor,but mine is modified and bent at a 45 degree angle to fit in the pipe,even if you stick something in there it hits the bend and wont go any further,I didnt try the bike out on the trails yet,just used it to get by the test,still not sure if my stock pipe will pass or not,because they dont have the manufacturer listed to tell them what RPM to use for the test,guess I pass no matter what!
