jdaatwebco
I attended the AHRMA race at Diamond Don's this last weekend. It was a hoot! Great turnout and site to race motorcycles.
The cross country races were dead engine starts. My 81 430 will usually fire off on the 1st or 2nd GOOD kick ( I have been racing dirtbikes over 40 years and Huskys much of that time). It took me 4 or 5 kicks to get started and by then the pack was long gone.
Although the 430 takes a lot to get going ( compared to other bikes-- even other Huskys), I can usually live with the 2 or 3 kicks it usually takes. But not in a dead engine start.........
Let me say that all the electrical connections are perfectly clean and grounded. The plug is gapped at .020. Timing at 2.0 BTDC.
Stock carb with a 45 pilot, 3.0 slide,420 main,6DH3/ T2, Q8 needle jet. The carb is perfectly clean, as are the jets. The carb ( or the parts) is not worn. I test and confirm carb jetting by reading the plug at each race.
I get to the starting line after warming the engine up and confirm that it is running cleanly. Kill the engine using the kill switch. Petcock is on. Stand on a stool, ratchet the kickstarter several times to get as much as I can toward the top while finding TDC. Watch the flagman and kick hard using no throttle until she fires.
Do you guys have success doing something different?????
