250-500cc Dead starting a WR300..Nothing to it
Discussion in '2 Stroke' started by Chums, Jun 11, 2013.
  1. Chums Husqvarna
    I'd like to discontinue my account
    So I spent about 30 minutes today doing dead start hole shots on my 13' WR300. The bike has the original Carb jetted by Halls as part of the set up of this bike. I'm 5'-10" 215lbs and one kick start this thing IN GEAR every time! I thought after reading some of the other threads it was going to be tough but it turns out nothing to it!
    Step1- warm up bike
    Step2- put bike in gear
    Step3- rock bike back and forth with clutch pulled in to allow clutch to disengage
    Step4- kick slow to get to top dead center then by hand push 1/8 kick past TDC
    Step5- allow kicker to go back up put foot on it and kick
    Step6- Hang on to your socks
    I did this every time I started it and began to get a feel for the kicker and eventually didn't need to push kicker with my hand anymore. Every time it started in gear and ripped!!
    burstcasino likes this.
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Out of curiosity, do you know what jets Hall's put in it when they rejetted it?
    I'm not running the TMX anymore, I like the power delivery of the PWK better, but I am always curious. :)
  3. Chums Husqvarna
    Not 100% sure what jets they used but they made it seem like no big deal just something they do during set up?? He did say when it gets hotter out (90deg+) I may want to lean it out a bit.
  4. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Since putting the Lectron on my 250 and getting it set right it will start 1st kick almost no matter how you do it. Sometimes I do a weak effort half kick just to see what it'll do and it still starts 1st kick. If you end up buying a Lectron for your 250 or 300 make sure to get a 38mm.
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I certainly didn't think much of the 36.:confused:
  6. Chums Husqvarna
    I was betting on the 38mm being the ticket and it seems it is! Good Info! I assume you have had the same experience as others, in that it has better mileage and smoother power and obviously better starts?
  7. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Yes, better mileage especially on tight single track and better everywhere with no lean or rich spots. It's by far one of the best mods for the money.
    huskybear likes this.
  8. Chums Husqvarna
    Cool, well I will have the Rekluse 2.0 and 10oz flywheel weight on Friday so I'll have to give those a try and then maybe the Lectron?? This bike should ride like a four stroke and be light all at the same time!!!
