TE/TC Decoding Map Switch Position
Discussion in '2st' started by Captain Kirk, Feb 16, 2016.
  1. Captain Kirk Husqvarna
    '15 FE350, '15 TE300
    2011 FE570S, '08 KTM 300 XC-W E
    Trying to figure out which position is which on the OEM dealer installed switch. Looking down on the handlebar switch from above, the thumb post can be in the 6 o'clock position and then can be rotated clockwise to the 7 o'clock position. Which position is what?
  2. Up-tite Husqvarna
    Just go ride it and see what does what.
    Only way you are going to know for sure.
    Later George
  3. Captain Kirk Husqvarna
    I tried that but with the Lectron, I can't tell.
  4. Up-tite Husqvarna
    Then no since worrying about it then?
    Just go ride and keep trying it. as if you get somewhere it is very slick and snotty then try and see if it makes it easier.
    Later George
  5. BDHANSON Husqvarna
    Southwest Washington
    2014 TC250
    There should be I and II positions on the switch. I is performance and II is soft.
  6. Captain Kirk Husqvarna
    Thank you! Finally decided to call the dealer and they were struggling a bit to tell me the answer, but they figured it out last night. Turns out there really is a detectable power difference in the two positions....or maybe it's the placebo effect. Thanks again.
  7. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    The ignition advance curve switch is an intelligence test.
    One position works very well, the other doesn't.
  8. Captain Kirk Husqvarna
    Now I understand why I failed it so many times. I will say this, on the 570, when switched from mild to wild, the bike transforms. No so in the case of the 300, at least not to the same extent.
  9. Norman Foley Husqvarna
    The change is subtle, but take it out on the worst snotty day you can find and you'll feel the difference...
  10. JonXX Administrator
    The change is extremely noticeable on my TC250 - position one sucks and the bike feels like it's out of gas until it's into the overrev zone, position two rocks and pulls hard from bottom to top.
  11. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Did you shut bike of to reset and switch?
  12. HS507 Husqvarna
    NE Ohio
    Te 300
    Last guy says position 2 rocks and other poster says 1 rocks and 2 soft. Guy that had desler figure it out never confirmed a thing?? So..... Know one really still knows?
  13. JBoone Husqvarna
    Charlotte, NC
    2016 TE300
    2005 ktm 300 exc (sold)
    Position 1 is the more aggressive. I can tell a difference but it is not a night and day difference. Position 2 smothes the throttle response and is helpful when the going gets tougher. You should be able to feel.the diff in more technical riding. Map switch came standard with my 2016 though was not installed when I picked it up for whatever reason. Very simple to put on. Nice to have a bit of tuneability on the fly.
    My dealer said on the 4 strokes the difference is much greater as compare to the 2 stokes
    jaxsplatt likes this.
  14. HS507 Husqvarna
    NE Ohio
    Te 300
    On fly? Im hearing bike has to be shut down and switched to remap?
  15. JBoone Husqvarna
    Charlotte, NC
    2016 TE300
    Not that I am aware of
  16. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    The switch really isn't needed. If you want to bypass the switch, just plug the connectors together under the tank. It would be an easy way to know what does what in regards to "feel"
    Lots of threads about this on the KTM forums too.
  17. DTX915 Husqvarna
    wr125
    kdx200 tt500 yz450 klx125
    From what I understand it really only knocked off a few RPM.
  18. HS507 Husqvarna
    NE Ohio
    Te 300
    I shut bike down and switch then restart. Still cant tell if there is a difference, this bike has alot of power anyway really
  19. Captain Kirk Husqvarna
    UPDATE
    I've received a few funny, non-helpful comments (really enjoyed them though), and a few PM's so I thought I'd just update. Now that I have the Lectron carb dialed in, there is a very detectable difference in terms of motor behavior. Position II as it is marked, is definitely the power position and combined with the clean snap of the Lectron and the power delivery of the Gnarly, the bike is a true tight trail weapon. FWIW - went to a 48 rear sprocket as the power is able to carry it and it gives the bike more legs.
  20. JBoone Husqvarna
    Charlotte, NC
    2016 TE300
    Shows I really don't know what I am talking about, I was sure that I could feel slightly softer power deliver in the II position!
    Placebo effect in full force, but I guess it also goes to show that there is not much difference to be felt, at lease the way mine is set up (no lectron, basically stock).
