Dellorto PHM 40 MS carburetor throttle cable replacement
Discussion in '610/630' started by Flynn, Apr 4, 2016.
  1. Flynn Husqvarna
    England
    Hi guys. I thought I had a sticking throttle but it turned out to be the bark buster cone nut, for lack of a better description. The bit that screws into the handlebar must have been slightly deforming the handlebar and causing the throttle to stick. Weirdly, if I disconnect the throttle cable it doesn't stick, the throttle tube rotates fine.
    So naturally from the above information I identified the throttle cable as the cause of the problem and thus set about to replace it. It was already broken in two places anyway so it wasn't too much of a waste of money you could say.
    Anyway I searched on Google for info on this specific carburetor and couldn't find much, save for the venerable advrider.com having a couple of threads related to it.
    So I took a lot of photos and decided to put them up on here, on a thread.
    The exact type of carb (a picture speaks a thousand words as always)
    Taking apart
    Could do with some cleaning
    Factory jet setting
    The other side of the barrel
    And the most important bit, this is how it all goes back together
    Whilst I had the carb off I decided to take a snap of the valves
    They sure look nice n' clean! 12k bike so to be expected.
    the carburetor very much reminds me of the injection pump on my 1.9 diesel turbo Pegueot 306. It's all rather old school mechanical in there, like in a diesel engine.
    Anyone got any tips and tricks for this specific carb, more power, etc?
  2. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    Delorto are not the best carbs. The brass needle jet (the part the needle attached to the slide slides in) in the carb body wears slowly over time (but fast compared to a jap carb) and makes the mixture too-rich over time. Replacing it makes the bike run like new. Cam.
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    Lectron if Kevin [at Lectron] and Kelly [at motosportz] can fix Scotts YZ 450 you can fix that
  4. Flynn Husqvarna
    England
    Good advice, thanks. What are the sights of running rich, other than a black spark plug? I would like to get the bike running as best as possible but it seems to be running fine at the moment hence me asking about signs.
    Not sure what you mean? I have read about Lectron carbs but what are you referring to about fixing?
  5. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    any carb related troubles you might have
  6. Flynn Husqvarna
    England
    I haven't had any troubles with the carb as of yet, it was just the throttle cable that I replaced and whilst I was in there I decided to do a rudimentary clean as well.
  7. Flynn Husqvarna
    England
    Also do you know if going another notch on the clip will give me a bit more power? I have a drilled airbox and the TE exhaust cans on. Also I am at sea level. Thanks.
  8. KXcam22 Husqvarna
    A wearing needle jet is insidious. It happens slowly over time and your bike runs a teeny bit richer all the time. You don't notice but observe that it just doesn't have the power it used to. The Lectron carbs are a great solution. Not that expensive and easy to tune. It is worth looking at. Delorto, amal, bing carbs all belong in the dumpster. I once replaced a Bing with a mikuni and was shocked at how much better the bike ran. Lectrons give an even better result. Cam.
    troy deck likes this.
