FE/FC Diagnostic tool
Discussion in '4st' started by R. Stephen, Mar 5, 2016.
  1. R. Stephen Husqvarna
    Any one know of any good and decent priced KTM / Husqvarna diagnostic tool available? 2016 model year compatible.
  2. bikesparky Husqvarna
    Townsville Oztrailia
    FE501
    Superduke 1290
    So far not. KTM or Husky dealer only.
    Last time I looked even KTM got locked out the Husky side and the other way around due to a dealer overstepping the line.
    The tool is constantly updated and checked over the internet too, so even if you get one from a dealer going out of business it will be locked out eventually.
    What do you want to do? Just upload a map or do the diagnostics also?
  3. R. Stephen Husqvarna
    Diagnostics check on the bike. No start, doesn't have fuel. Don't think the fuel pump is coming on. A nice plug in tool to check codes would be nice like automotive.
  4. bikesparky Husqvarna
    FE501
    Superduke 1290
    Yes I know, it makes things so much easier. I used a system like that on the road going KTM's for years (tuneecu) but it doesn't work with these bikes due to canbus communications.
    Best thing to do is undo the fuel hose and put it in a jar or back in the tank with a length of other hose and push starter button. Just keep the hose securely in place as it's high fuel pressure.
    The system is reasonably simple, if the ECU sees the crank sensor it starts the pump and spark. If you have neither fuel nor spark it's ecu or crank sensor related. If only fuel is missing check pump.
    You have a friend with similar bike, just swap tanks for a try.
  5. R. Stephen Husqvarna
    Yeah I got it up and going again. It just seems crazy there isn't a good tool out there for this. Is so common in automotive and powersports vehicles are so far behind as far as that is concerned.
    Thanks.
  6. Aviator Husqvarna
    Chattanooga, TN
    2015 501 S
    2007 BMW K1200S, 2014 BMW R1200GSAw
    The GS 911 for the beemers are supposed to get the KTM/Husky ware on it soon.
    bikesparky likes this.
  7. bikesparky Husqvarna
    FE501
    Superduke 1290
    That would be great!
    On the road bikes a lot of the parts are similar, like the Bosch ABS and so on. Once the access protocol is cracked it should be all go.
