CJBROWN
Now that the bike is all dialed in and setup I'm working on a way to carry more gear to enable camping off the bike. I've got the rack setup, can use a rotopax fuel, duffel, or Wolfman Rolie for day trips. Works really well.
For side bags/panniers I really can't decide between the Wolfman Expedition bags and Dirtbagz Rangers. Berg is finally done with the racks for Wolfman so that is actually now an option.
Wolfman:
(BTW, do these make my rear-end look fat????
Dirtbags:
Although these bags are not loaded they still appear to be a bit slimmer than the Wolfman setup.
Here's what I've come up with as pros and cons for each...
Wolfman pros...
waterproof
packs tight to the racks
large capacity with the Expedition bags, or use large Rolie bags for a more compact set
can add fuel bottle or water bottle holsters for more capacity
Racks can be used for hauling other cargo, pax, pellican boxes, etc.
Cons
seems like they stick out too far
lots of straps, although I really like the medium Rolie bag I got, they work REALLY well
Seems like it rides further back and higher than Dirtbagz
Cost - they are quite a bit more than Dirtbagz
Dirtbags pros...
Simple and slim profile
one bar left when the bags are removed
Cost - $250 for the whole setup is a bargain. About 40% less than Wolfman Expedition saddle bags
Cons...
not water proof
reports of broken support bars particularly if you lay the bike down on them
finicky zippers
Did I mention not water or dust proof?
Sometimes they look like they hang funky particularly when fully loaded
So, I'm in a real quandry. Each has it's merits, one costs a lot more. I'm not sure how often I'll actually use them, but probably a few trips a year. For either I'll add a top bag for extra capacity, and plan to leave the most of it campside for any really tough trail riding. The bike doesn't handle all that well with even just 30lbs on the rear cargo rack. I can't imagine doing any kind of really tough trail with a full load.
I've read dozens of posts all over the internet, pros and cons for each, and each has their following. Both seem to have really good customer support, and both are made in the USA. And yes, Eric at Wolfman has been sewing up the bags for DBZ Products since the beginning.
It may just get down to cost vs. how much they'll get used and I'll end up with Dirtbagz. But I really like the way the roll top bags from Wolfman work, and the added versatility of their design. Plus they're waterproof! But then I really don't like riding in the rain. Then again, if you get caught out in a down pour it would be nice to be able to setup camp with dry gear.
Is there something I haven't thought of?
Which way would you go and why?
EDIT: BTW, here's a really good pic of Pinocono's Dirtbagz setup, from the top:
Wolfman:
Dirtbags:
Wolfman pros...
waterproof
Cons
Dirtbags pros...
Cons...
not water proof
finicky zippers
