display is out, advice needed
Discussion in '610/630' started by 04asphalt, Sep 11, 2010.
  1. 04asphalt Husqvarna
    SW Michigan
    08 te610- first the little wrench symbol stopped showing a few weeks back, then the second digit for speed display and now all led display is gone.
    anyone not having issues with their computer or is mine just one out of the bad batch? are the 2009 any better and will it work? trail tech the best after-market option?
    :excuseme::confused:
  2. K7MDL Husqvarna
    Woodinville, WA
  3. nickterc Husqvarna
    TE 610ie
    DIsconect the battery terminals wait few minutes and connct them again.It worked on mine.....
  4. LRPct Husqvarna
    NW connecticut
    happened a few times to me as well.. sometimes takes an hour or so of being disconnected to work again.. Usually 10-15 minutes works tho..
  5. 04asphalt Husqvarna
    SW Michigan
    how much can a replacement be had for? is the 09 the same?
  6. MASTER_E Husqvarna
    Gladstone, OR
    That sucks your's stopped working, my buddies 08 SM610 just went out the other day as well. I've looked at the Vapor options available but what about your odometer? Can you put your original mileage into the new one or do you have to start from 0 again?
