DLS brake ajustment
Discussion in 'Vintage/Left Kickers' started by Northern Husky, May 5, 2010.
  1. Northern Husky Husqvarna
    Canada
    Hello All,
    lve fitted front DLS brakes/forks on my bike, with new pads. lve found myself about an inch of 'inner' cable short.
    How do i free up some slack? For example on the rear drum brake you can move the actuator arm around on the splined shaft, is there a similer ajustment for the front?
    Cheers
  2. crankpin Husqvarna
    England
    Cut some outer cale away, or buy the correct cable
  3. Northern Husky Husqvarna
    Canada
    Yep crank, im with you mate, you can usually wiggle of the brass cap at one end or the other, and take off the outer skin with a small disc on a dremill, lve had to do this on snowmobiles when using cable extentions....................not a "Monday morning " Job :cheers:
    & Thanks for the imput.
