Do you have a squeaky front brake on your TE630??
Discussion in '610/630' started by Huskyfly, Jan 16, 2012.
  1. Huskyfly Husqvarna
    North of the Columbia River, WA
    Looking for my next Husky......
    2016 Africa Twin, 2013 TE310
    I know I've been told it's normal, even more so when you ride more dirt......BUT........how squeaky is your front brakes?? Mine squeal like a pig at the fair :lol: even when I'm ginger with them?? Does everyone else's squeal?? Any thoughts??
    Also, dumb question time.......how the hell do you activate the hazard flashers?? I know, I know, I should look in the manual but just tell me?! :lol::D
  2. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    AFAIK, all Huskies do that. Yet, when I'm out riding with friends, mine is the only bike (I have the only Husky) that thinks the hills are alive with the sound of music.
    Huskyfly likes this.
  3. KLOC Husqvarna
    Edmonton, Alberta
    The bike has hazards? I've seen nothing in the manual about hazards.
    I chamfered the leading edge of the brake pads to cut down on the squeal.
  4. capt42104 Husqvarna
    CenCal
    Mine just makes the metal on metal sound that sintered pads make! I hate it.
  5. KLOC Husqvarna
    Edmonton, Alberta
    I think George @ Uptite has better pads.
  6. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Mine howled like a freight train. No amount of cleaning & greasing would fix it. Per Hall's Cycles recommendation, I put some EBC X pads on. Howl is gone.
  7. EricV Husqvarna
    Mine has 1600 miles on it so far and the pads have never squealed. Perhaps you need to put pad grease on 'em (behind the back plate where it contacts the piston)- don't know...just know that's best done w/ cars.
  8. mbr440 Husqvarna
    Victoria B.C.
    11 TE630 13TE310 14 TXC310
    86 VFR750
    I have had some minor squealing but nothing to complain about. Does anyone else have the Rotor touching the caliper carrier like mine does? Under braking at slow speeds it makes a ticking sound. I have done the front axle/ fork alignment trick and it is still the same..
  9. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    Like I said, no amount of cleaning & greasing (including putting automotive pad grease on the back side of the pads) cured my howl. Different pads did the trick.
    That doesn't look good!
  10. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    1400 miles, no noises.
    However the rear brake fluid turns black, flushed mine out with new dot4 by recommendation from Johngil. His coolant was pretty black too.
  11. mbr440 Husqvarna
    Victoria B.C.
    86 VFR750
    No it doesn't.. It barely touches but ....I need to look a little closer and take the wheel off.. Maybe the wheel spacers were installed wrong when the dealer assembled?
  12. ray_ray Mini-Sponsor
    The Philippines
    Mine was like this so I put some small thin washers to space the caliper away from the disk .. try to move both the top and bottom of the caliper to keep it spaced equally ...
  13. mbr440 Husqvarna
    Victoria B.C.
    86 VFR750
    Thanks... I will give that a go..
  14. mnb Husqvarna
    putting washers in sounds like a hack to me. Something's wrong if it doesn't mount right.
  15. mbr440 Husqvarna
    Victoria B.C.
    86 VFR750
    Well I must say.. I have owned alot of Hondas and I have never Tinkered so much on a new machine.. But I have come to terms with the Qausi Exotic nature of this beast.
  16. ContraHusky Husqvarna
    Funny thing...my stock TE wheel squeeks. The SM wheel doesn't -- even with the exact same rotor installed on it.
  17. littlehandegan Husqvarna
    About how many miles should we get out of pads/rotors?
  18. EricV Husqvarna
    Man, that'll be highly variable. It of course depends on the type of riding you do, riding style/how assertive you are with braking, brake pad type/material, temps, etc. Mine's a TE630 w/ 5600 miles on it now and I replaced the pads (F & R) at around 4600 miles. By the way neither of my sets have presented any squeal whatsoever.
  19. Fast1 Husqvarna
    Minneapolis, MN
    Riding mud will take the pads down quick, especially the back. My fronts on the TE and SM are quiet and do not squeak. odd..
  20. capt42104 Husqvarna
    CenCal
    Hey there,
    I put Galfer Green pads on mine at 500 miles cause i couldn't deal with the metal on metal and relatively hard two finger pull effort....in fact, I have never liked sintered pads and have eventually replaced all the sintered pads on every bike i have had in the last couple decades with Galfer Green or Black pads, or EBCs if i cant get Galfers (street and dirt). I just prefer organic, semi-metalic, or the newer Kevlars, for initial bite and extremely low rotor wear. Since i like to wash my bikes monthly (or more) the extra brake dust associated with non-sintered pads are not a big deal. I can say i haven't ever had brake squeal like my buddies do on their bikes.
    With about 3k miles on them now, the fronts look 80% and the rears are still new.
