125-200cc Does anyone ride a 2009 CR125?
Discussion in '2 Stroke' started by herpindo, Dec 4, 2009.
  1. herpindo Husqvarna
    Bali
    Looking to exchange helpful tips and info with any other 2009 CR125 riders, let me know if anyone is out there!
  2. vntgmx Husqvarna
    NJ
    Have one and here's a couple of things you need to address.
    1.Pipe will rub shock resevoir,you need to tweak the bracket to get a smig more clearance.
    2.Kicker contacts pipe.You need to space it out a hair.
    3.Jetting will need a little tweak.I forget exactly what I did but if memory serves me I richened up the needle one,adjusted the air screw and idle and it rips now.Stock it has a lean bog when transitioning from low to mid.I know I didn't have to change any brass.
    4.For myself I softened up the clickers on both the front and rear but more so the forks.It will vary based on your weight,ability etc..
    Good luck and enjoy it and let us know if you run into any good adjustments etc.. :thumbsup:
  3. rpmguy Husqvarna
    Oregon
    I thought all the 09 cr got recalled?
  4. rancher1 Husqvarna
    WA
    He is not in the US, location is Bali.
  5. rpmguy Husqvarna
    Oregon
    Oh your right. I did end up with an 09 cylinder on my 08 CR125. Swapped one out before 09's got sent back on recall. I may have one of the only 08 CR125 with a 09 cylinder in the states.
