does the fuel line click in see pic
Discussion in 'EFI/carb' started by jonny08te510, Aug 9, 2013.
  1. jonny08te510 Husqvarna
    swan valley, western Australia
    2008 te510/2011 tc449
    99cr500/99af500 project need a donk
    There's no leaks I noticed I just fitted a jd and had trouble reconnecting the the fuel line to pump it doesn't seem to click into place is this normal.Is the gap seen in pic normal I think it's in as far as it can go
  2. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    It should click, just tug on it, if it doesn't pull off, it's on. There can be a gap and it still be on right.
  3. jonny08te510 Husqvarna
    It's quite hard to pull off the 2 white pieces u squeeze are old/worn that's why don't think clicks in properly
  4. organ donor Husqvarna
    Berlin
    Mine (630) didn´t click in after I installed the JD. So it came off in the middle of a long Autobahn tunnel. They had me on the TV monitor and got me out. They even got me some fuel to put in after I´d done the repair.
  5. jonny08te510 Husqvarna
    So how did you repair it just by getting it to click in properly ?
  6. organ donor Husqvarna
    Berlin
    Just make double sure that it goes fully in and .... CLICKS!
  7. jonny08te510 Husqvarna
    Ill have to order another one because it doesn't click its obviously no good still riding the bike and no leaks but checking it regulary
  8. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    The pump assembly puts out 43psi, if it's not locked in, it WILL get pushed out.
    Sometimes, when I put mine back on, and I am not lined up straight, there is not much of a click, you have to have the hose piece heading onto the red fitting really straight for you to get a good click.
    organ donor likes this.
