250-500cc Doing away with motoplat
Discussion in '2 Stroke' started by mik430cr, Aug 18, 2014.
  1. mik430cr Husqvarna
    Canada
    Cr430, cr250
    Kx500, rm500
    1982 cr430 has ignition issues, I am considering retrofitting a 1983 honda cr480 complete ignition system. Has anyone tried this? Is the crank taper compatible?
    I can machine a mounting plate and make a new cover. Honda parts are so plentiful, cheap and reliable it's worth a shot.
  2. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Check with Penton Imports for a complete system. They are reasonable, reliable, and generally a direct bolt-on.
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the motoplats can be rebuilt, or you can use a new replacement ignition from many sources..i myself dont mind the motoplats. easy to time and pretty reliable if you dont mind dim lights
    by the way, this forum is for the italian bikes, you will get more answers if you post in the left kicker section
