TE/TC Don't get stuck (suspension) thoughts
Discussion in '2st' started by robertaccio, Aug 3, 2016.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    I get to a place and don't like to play too much.....stuck.
    plus in between services internal may change a little as well. Or external changes happen like a big tank=more weight.
    Yesterday I went into playing with my forks again....ended up 2 clicks in on Comp and 3 more clicks open on REB, the bike felt much higher in the front and I thought too much but when I hit the ugly stuff and even the sharp winding corners of our tough one loop- the bike felt sooooo good and way more balanced. These things don't take much to throw them off or work them into your own personal nirvana
    gots_a_sol, NCSteve and Norman Foley like this.
  2. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Yeah, when you get used to something, it's hard to justify turning clickers. Ya gotta stop grab tools and remember where you started. I just don't mess with mine much. It took a guy like Ty to notice my rebound was way outta bounds watching me ride. I was like oh, that's much better. But for numb skulls like me, unless it's goes metal to metal, or tries to throw me like a bronco, it's good enough. I really need to take a day or two and mess with stuff.
    steadydirt likes this.
  3. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    True for me too.- started out on a '82WR happy as a clam UN-ajusted - had a ton of fun. Years later started to pay attention and adjust my stock suspension. Way better. More years later I will not ride stock suspension anymore. Using proper valving, oils, etc. Way better-er. In the beginning I thought suspension was voodoo- free at last. I had to learn I could adjust it and try it and if I did not like it return it to previous settings or try a new setting. I have ridden everything I have with the clickers full in and full out- had to see what it felt like.
  4. Bigbill Husqvarna
    '83 250wr
    0 right now
    Take notes keep a record of the moves you make.
  5. robertaccio Husqvarna
    San Diego, Ca
    I have tape on my crossbar pad that I write all my settings on with sharpie permanent marker, I just cross out the old and write the new.
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I think I know what you mean, sometimes I reflect back after a ride and realize the bike was doing something funky in certain situations. Yesterday while riding I noticed my rear shock spring was feeling soft and then remembered when I got my suspension revalved it was a toss up between 5.8 and a 6.0... I went 5.8 and that's when I weighed 210 lbs. Now that I'm 215 lbs and I've also learned that someone as tall as me can and should go stiffer I'm thinking of trying a 6.0 or 6.2.
  7. robertaccio Husqvarna
    San Diego, Ca
    oddly enough the WP factory services guys set me up with 5.8 said this was their max that they like to use, they also told me straight up not to worry about static sag just set your race sag, 100-105.....so even they have their own thoughts about this stuff.
    I have always stuck with the @35mm static/100mm race sag for linkage bike formula---which puts me on 6- 6.1 spring
    Also Ty Davis told me he likes a lighter spring on his 2 stokes and uses short static settings @ 25mm and even less to get that 100-103 race sag number with a lighter spring
    FYI stuff to consider.
    For me I like the short race sag so @ 100mm is my goal in set up
  8. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    I like heavy spring light valving.... I try to stick to 100mm
    robertaccio likes this.
  9. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Ty helped me set the sag on the 2fiddy after we got the right spring in there and he serviced the TTX and I gotta say the thing is like butta. The chopped wood pit at LDS was easy.
  10. lankydoug Husqvarna
    MO
    WR
    TM 300en
    My son's race bike is set up 6.4 5.2 and he weighs the same or a little less than me but is 6'8" and much faster then me (6'6" and slow). When I ride his bike it feels perfect, the faster you go the better it gets. His suspension guy told me to set his rear sag to match the front, I cant remember what the number was but I know it works better than any bike I have ridden.
    robertaccio and juicypips like this.
  11. robertaccio Husqvarna
    San Diego, Ca
    BALANCE is the key word.
    racemx904 likes this.
