125-200cc Double petcock setup on 2013 WR 125 tank
Discussion in '2 Stroke' started by AUSKY, Nov 5, 2013.
  1. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    Has any one installed a dual petcock system on a 2013 WR 125?
    I can see on the bottom of the right side of the tank a moulded shape in the tank that looks the same as the fixing point for the existing petcock. It looks like it would work. I'm just not sure if the thickness of the plastic of this area will allow adequate fixing and sealing of a second petcock.
    I was wanting to be able to use the entire tank of fuel without having to stop and drop the bike to the left to empty the RHS wing of the tank.
    PineapplePicker likes this.
  2. retromlc Husqvarna
    Kent,England
    TE 250i 2018
    Beta Evo 250 4/
    theres a thread on here about it,it can be done easily
  3. DRS Husqvarna
    renton
    wr 165
    500 exc
    i did a dual petcock setup on the ims tank i have, was pretty easy once i figured out how i wanted to route the right side line.
  4. AUSKY Husqvarna
    I'm trying to do this to the stock tank though
  5. AUSKY Husqvarna
    Cool I will have to do a search. Thanks Retromic
  6. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    2004 Harley-Davidson FXSTI
    This is on my mod list things to do.
  7. huskybear Husqvarna
    B.C. Canada
    I
    I have done this mod a while ago, check my thread "making the most of your stock wr fuel tank" it works great! Hope this helps you out.
    PineapplePicker and Jersey Woods like this.
