Hey all,
been sucking up the awesome knowledge on this site for a while now, but have a conundrum of my own now.
background:
2000 model husky, ate its top and bottom end up in a big way about 5 years ago. a mate got hold of it knowing this and eventually sent the complete engine down to R&D husky here in australia 6 months ago. Engine got a full top, bottom and jug (went near on 2k, whoa!) and when it was returned ran "good" for about 2hrs total running time.. last ride, it started bogging down badly at mid-high throttle, then died with no sign of life.
we've since been right thru the electrical system and verified it all good (not the first stator ive needed to check), stripped and cleaned the carb. (not the first carb... you get the picture
), tried fresh fuel and made sure air filter is clean (as in, actually cleaned and re-oiled because it was a bit grimey)
these are its current settings, we ride @ ~200-500m ASL, temps from 15-35 deg C.
Stock TMX Carb
6AEJ3-64 needle, top clip
primary - 30
main - 390
keep in mind, these settings were quite ridable previously
now, when we start the bike it will idle ok for a while (~3-4 mins), then eventually foul the plug till it stops.. using the throttle to rev it up some makes the foul come sooner. air screw and idle speed dont seem to do anything. (weird...)
pulling the plug, cleaning it with carb cleaner, clearing out the cylinder then refitting allows the same thing to happen next start. we've got it running then jumped on for a fang, plugs fouls quickly due to throttle usage.
Im after some ideas from you all here, as this is running towards the boundaries of my troubleshooting skills..
gut full of premix oil?
leaking floats (doent leak out of overflow, no matter how long u leave it parked with fuel on?)?
leaking gearbox-side seal?
act of god?
help me please guys, i want to experiance the howl of a 360 on full song.. ive ridden this thing years ago, its a buzz (as im sure you guys know!) and im keen to sample it again
cheers!
background:
), tried fresh fuel and made sure air filter is clean (as in, actually cleaned and re-oiled because it was a bit grimey) these are its current settings, we ride @ ~200-500m ASL, temps from 15-35 deg C.
Stock TMX Carb
primary - 30
main - 390
act of god?
cheers!
