Drive Washer Removal
Discussion in 'Vintage/Left Kickers' started by hoppy, Mar 6, 2016.
  1. hoppy Husqvarna
    Melbourne, Australia
    CR250 1982
    Husky 701 & TE250 17
    Hey all whats the best way to remove the drive washer I need to change the pins or replace the washer.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    It is pressed in, over top of bearing.
    Just go in from other side and slide the main spacer over between both bearings ( it stays centered with foam in the hub), and drive it out with an aluminum or brass rod. Then replace both bearings.
    If foam is yucky, go to home improvement store and get pipe insulation foam, for new piece. I get the stuff that doesn't absorb water.
    Then while your at the store. Go to there bolt bins and find a new roll pin the same size to replace broken off ones.
    grouty, oldbikedude and hoppy like this.
