Drop Link & Drag Link Bearing Service TE 310
Discussion in '4 Stroke' started by 2wheeler, Aug 18, 2016.
  1. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    How often to clean/grease the bearings?
    The WSM states for racing Lube @ 10 hrs otherwise Check @ 6k miles.
    I pulled one Drag Link bushing and of course there was dirt in the groove of the rubber seal. The Bearing appeared clean. Was able to clean the dirt from the seal with a Q-tip.
    I am tempted to do the same to the rest. Add grease to the bushings and bolts then reassemble.
  2. ghte Husqvarna
    Bright, Victoria Australia
    I generally pull the swingarm and linkage down twice a year, maybe one more time if the riding has been consistently wet and muddy. Generally the steering stem head bearings once-twice a year. I always use heaps of waterproof marine grade bearing grease.
    R_Little and 2wheeler like this.
