bmwpowere36m3
Hey guys, I found this forum when I was searching for suspension valving info and found a member, Tyle Tarry who had some info. He said he was willing to share some info, so I'm creating this thread.
I recently acquired a 2000 DRZ400S and its in need of some suspension work. I ride in the Northeast, mostly single track (2-3 gear stuff) that's rocky (softball size) and rooty. I weight 180 lbs without gear. With some small jumps and whoops thrown in. Overall I'd say the bike is fairly soft and on rocky bits when I have some speed the bike doesn't instill confidence. Also when hitting small jumps and ledges the front end drops and the rear kicks up. Going over whoops is a nightmare... thinking I'll get thrown over the bars.
I'm in the process of swapping over to newer DRZ suspension components because the old shock lacked rebound and HS comp adjustments and the forks are damper rod style.
I just got a DRZ400E shock and I'm still waiting for a set of forks. At the same time I’ll be picking up some 5.7 kg/mm rear springs and I'm not sure as too the forks. Many seem to use 0.46-0.48 kg/mm at my weight on the DRZ sub-forum.
I figured I'd ask if there was any revalving advice while I have the shock apart for service.
2003 DRZ400E Stock Shock Shim Stack
- 12 x 1.25 NUT
- 25 x 3 PLATE
- 25 x 0.6
- REBOUND
- 24 x 0.30
- 26 x 0.30
- 28 x 0.30
- 30 x 0.30
- 32 x 0.30
- 34 x 0.25
- 36 x 0.25
- 38 x 0.25
- 40 x 0.20
- 25 x 0.10
- 40 x 0.20 (6x)
- PISTON
- COMPRESSION
- 44 x 0.20 (4x)
- 44 x 0.15 (3x)
- 34 x 0.15
- 26 x 0.10
- 42 x 0.20
- 40 x 0.20
- 38 x 0.20
- 36 x 0.20
- 34 x 0.20
- 32 x 0.20
- 30 x 0.20
- 28 x 0.20
- 26 x 0.20
- 24 x 0.20
- 22 x 0.20
- 40 x 0.30 (2x)
- 41 x 4 PLATE
- 18 x 0.60 SPACER
) is not position sensitive on 99% of forks, it is only speed sensitive.
