Dual map switch
Discussion in '4 Stroke' started by HUSQVNA, Aug 21, 2009.
  1. HUSQVNA Husqvarna
    Arizona
    Does anyone have an online source for the dual map switch? Looking to put one on my 09TE 310. Like to leave Map 1 on the stock settings and use Map 2 as my testing ground for comparison! Thanks!
  2. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
  3. HUSQVNA Husqvarna
    Arizona
    Thanks, will see if they are available online. Just pulled the trigger on the new iBeat software & cable . Can't wait!!! I'll let ya know how it goes, but need to get that switch, el-pronto.
  4. LarryS Husqvarna
    fremont, ca
    Or better yet, can someone just explain what the switch does,
    then we could use any switch.
    The switch just connects 2 wire together or grounds a wire.
    anyone ?
  5. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    You got the software (iBeat) too.? How much?
  6. seanoj Husqvarna
    Los Angeles
    I ordered my dual map switch (2009 TE 310) from Hall's. Came very fast. Easy to install. The second map makes power in a much more sublte way. Great for greasy, sloppy, mossy river rocks, etc. It was cheap too.
    Have used it only once. Not much wet where I ride. Nice to have though.
    -Sean
  7. HUSQVNA Husqvarna
    Arizona
    Super, I'll give them a call Monday. My hope is, and someone please let me know if I'm off base here, I'm going to be able to keep Map 1 stock, and use Map 2 for making changes with the iBeat software and the good old fashioned "butt dyno" (test riding).
  8. Ex HVUK Husqvarna
    England
    None
    I haven't actually tried switching between modes when connected to the ibeat but I'm pretty sure you can't do what you are suggesting.
    I believe the dual mode switch primarily alters the ignition advance to soften the power delivery rather than altering the fueling.
    If you want me to 'try before you buy' I can but it won't be until Tuesday - let me know!
    Dave
  9. husky123 Husqvarna
    Leesburg, VA
    Yes it just alters the ignition curve, no fuel changes.
  10. HUSQVNA Husqvarna
    Arizona
    REALLY appreciate that offer, but I was able to confirm what ya'll are sayin about the ignition curve so I guess it's a mute point in regard to what I was "hoping" for! Got some FANTASTIC information about what I can do with the iBeat from a gentalmen on here who is clearly an expert in all things EFI so I'm off the dual switch idea, at least for now! Thanks again guys.
