250-500cc Dumb air screw question
Discussion in '2 Stroke' started by Jhunter, Jul 8, 2013.
  1. Jhunter Husqvarna
    Atlanta
    Due to summer heat and humidity in Atlanta, my bike is running a little rich ('08 WR250). I'm thinking a half turn on the air screw may do it. So here's the dumb question. If I turn the screw clock wise, am I going leaner or richer?
  2. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    not a dumb question... in is richer, out is leaner :thumbsup:
    EDIT: just to point out, the air screw is not visible in your pic. that center Philips w/locknut is the idle screw. the air screw is just behind the fuel hose in this pic.
    and some tips in case it helps:
    john01 likes this.
  3. Jhunter Husqvarna
    Atlanta
    Typeone - I had a 'senior moment' on the idle adjustment screw... So, just behind that tucked up tight is the brass air screw. Good notes above. I'll make some small adjustments until I get it figured out. The jetting is great and I really have no complaints about the carb so let see if this works for the summer temps. Thanks!
    typeone likes this.
  4. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    no sweat :)
    i'm sure you know, but the Stealth Racing idle screw and ZipTy air screw make these quick adjustments sooooo much easier. nice upgrades.
    john01 likes this.
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I put one of those nice spring loaded idle screws on my Mikuni.:love:
  6. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    How many turns out are you? how does your bike start when warm?
  7. Jhunter Husqvarna
    Atlanta
    Every time I post, I find some new little 'tip or trick'. That spring loaded idle screw is perfect. I think I'll order of of those this week... Thanks Dirtdame.
  8. Jhunter Husqvarna
    Atlanta
    A half turn 'open' on the air screw made a huge difference. Once the temps drop and the humidity goes back down, I'll richen it up a little...
