Duz the terra engine use any oil
Discussion in 'TR650' started by Lowrider1963, Feb 14, 2014.
  1. Lowrider1963 Husqvarna
    650 terra
    BMW 1200gsa
    I'm planning a small tour around Scotland on the terra just wondered if I need to take a ltr of oil just in case,
    So as any of you done a tour with your terra has it used oil
    Thank for any feed back
  2. AJM6000 Husqvarna
    Western Australia
    Harley Davidson FLTRX & Ducati 749s
    I've done 2 oil changes, both after 3000km and the bike hasn't used any oil. That's running it 30% on trails at varying rpm, the other 70% is on road at open road speeds around 100 - 120kph. I'm confident mine isn't using any. Interested if others are with more than 7000km on their bikes???
    I think there are a few on here with more than 25,000km, so they should be the best indicators??
  3. Chuffa Husqvarna
    Perth, West Australia
    TR650
    XT250
    Don't worry about taking oil. I've not needed any. My longest tour so far is 3500km & with plenty of km on the TR650 I don't think oil use is an issue.
  4. HuskyKT Husqvarna
    Cape Girardeau, MO
    2012 TE 310 & 2013 TR650 Terra
    4 Suzuki GV1200 Madura
    Bought my bike with 3800 miles on it. I found the air filter kinked up and not sealing. Now I have 7500 miles on it and is using about qt per 1000.
  5. Next Strada Demolitionist
    Brevard, NC
    A quart every 1000 miles? My bike uses none at similar mileage. That's half the total volume every 1000 miles.
  6. drzcharlie Husqvarna
    Yup, what Next said. No oil use ever.
  7. glitch_oz Husqvarna
    AUS
    Strada
    With that sort of oil consumption it might be high time to check the sand-depth in that airbox ?
  8. drzcharlie Husqvarna
    +1 on the sand depth...too funny.
  9. HuskyKT Husqvarna
    Cape Girardeau, MO
    :eek: I believe all this happened before I bought the bike. I am afraid to look
  10. drzcharlie Husqvarna
    I'd look inside and pick a mod, any mod. IMHO those that aren't changing the filtering arrangement are missing the boat. It needs good filtration and doesn't have it. Believing that design parameters will take care of cleaning the air (It should but doesn't) isn't going to work in this case. Good luck!
  11. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Just run it dry. Oil is overrated.
  12. Riding Again Husqvarna
    Palm Coast, FL.
    2012 TE511
    Sold TriumphTiger800xcx, TR650 Terra
    I have 12k miles on stock air system use no oil. I have only taken it offroad 2 times so not a lot of sand and always paid attention to it. Doing the 3d printing method shortly. Waiting on glue and uni filter left.
  13. glitch_oz Husqvarna
    AUS
    Strada
    Seconded.
  14. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    The filter mod is a must do for all, but more critical for those of us that get off pavement. I did one dirty ride and previous pics show what happens. Thankfully I made corrections before any real damage occurred. Use 150cc per thousand now.
  15. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    I changed the oil in mine last week at 15,000km. 4000km since the last oil change. The oil level was registering on the bottom 1/4" of the dipstick just over the MIN mark. 1800ml of oil drained out (oil and filter change). The bike shop did the last oil change, so I can't be certain exactly how much they put in, so I don't know if it was just filled slightly low, or if it is using a bit. I refilled it with exactly 2 litres which gives an oil level reading about 2/3 of the way up the stick between MIN and MAX. I'll keep a close eye on it for the next few thousand km and see how it goes. If it is using oil, I guess it's only using 50ml/1000km.
  16. Riding Again Husqvarna
    Palm Coast, FL.
    2012 TE511
    Did you change the oil when it was hot or cold? I have only noticed the change when hot and cold. I have 13k miles so far.
  17. drzcharlie Husqvarna
    You should warm the bike so the oil is more viscous. I don't like to get it hot because removing the crankcase plug burns my delicate little digits when I remove it.
  18. nev.. Terrarist
    '13 TR650 Terra
    '14 XT1200ZE
    I ran through the recommended oil level check procedure prior to draining the oil. Idle the engine till the fan comes on. idle a few more minutes. Check the level. Drain the oil. Replace the filter. Replace 1.5 litres of oil. Run the engine for 30 seconds. Add another 500ml of oil. Then I took the bike out for about 10 minutes riding. Back home, let it idle till the fan came on, idle a few more minutes. Check the level.
    I think on this bike it's particularly important to get the oil nice and hot before draining. There are two oil drain points. The drain for the top oil tank is only 10mm (2/5") wide. The drain for the sump plug is 25mm (1") The majority of the oil is in the tank and must drain through the small drain hole in the tank hose. I wouldn't expect the oil in this engine to get so lumpy that it wouldn't pass through the narrow tank drain when cold, but its' sure going to flow out smoother when it's hot.
    PaulC likes this.
