Economy windshield
Discussion in 'TR650' started by RockinRod, Apr 18, 2013.
  1. RockinRod Husqvarna
    Eastern,N.C.
    TR650
    79 GS850G, 99VFR800Fi , 04ST1300A
    Hi Guys,
    I have been wanting a screen a bit taller for road duty. The situation on accessories is asa we all know not good....So, I took up tools...not in the van the Terraformers did but simple hand tools....
    Utility knife, bench grinder hand held heat gun .....A piece of Lexan from my local Lowes and some automotive door edge guard to make it purty......First off I laid the black shield over the lexan to start a template....then the heat gun to put the bend in the middle....then I went to the bench grinder to spruce up the bottom and top of it all....I used the heat gun a second and third time to get the bends down at the bottom of it where the bottom two screws go through....After all of the angles were covered I laid the shield under the lexan and used a marking pen to locate where the screw holes would be placed..... A pilot hole was made for each place then opened to the correct size and last of all the edge moulding installed around the screen{its not just lexan any more its a screen now}and used a pair of side cutters to trim....I'll try to attach photos.....If I can do it anyone can...
    Rod
  2. Next Strada Demolitionist
    Brevard, NC
    VERY nice! Looks a lot like the factory screen I just installed. What did this project run you, if you don't mind me asking?
  3. spiderman Husqvarna
    Decatur, IL
    07 KLR650 07 Bandit1250 85 Rokon
    Good job. What thickness is the Lexan?
  4. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    If anyone is trying to duplicate this, please be sure to use the Lexan (polycarbonate) and not the acrylic. They look the same and are right next to each other in the store, but the acrylic will shatter where the Lexan will bend. I'd hate to be running down a rough road and have it break apart.
  5. Motosportz CH Sponsor
  6. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Great job. I was thinking of making mine with a dark tint to keep sunlight off the instrument panel. Is there any way to stop the edge guard from bulging around the radius of the corners? Can a heat gun shrink or form it?
  7. FER QUILES Husqvarna
    SPAIN
    TR650
    KLE500, HONDA NX650
    It looks very good job. congratulations.. What about the turbulence ata 65mph??. someone??.
  8. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    I've got lots of spare lexan at the house, and have been thinking of just such a build. A bandsaw works great for cutting lexan, just use fine teeth and push it slowly. You can actually achieve somewhat of a polish on the edges by sanding them with ever increasing grits of sandpaper.
  9. RockinRod Husqvarna
    Eastern,N.C.
    TR650
    the lexan sheet was $3.98 and the mldg was about $5.00 from Pep Boys and the thickness is..080
    Next and spiderman like this.
  10. RockinRod Husqvarna
    Eastern,N.C.
    TR650
    Well had time to get out on the Terra today, no turbulence and no ill effects from it either, I really don't think it made any difference.....except the looks department.....
  11. Wadejesu Husqvarna
    TR650
    HD, Ducati, Triumph, Aprilia
  12. joebtx Husqvarna
    Fort Worth Tx.
    I think I paid $69 for the shield on mine, and I really like it. The wind hits me at just about eye ball height and there is not near as much turbulance as without the shield.
    JoeBtx
  13. Thomas Riser Husqvarna
    Portland Oregon
    2013 Terra 650
    CR 250
    Where did you pick it up? Is it easy to detach? I just think this might be a bit tall for me in the woods..
