Juvkam78
		Hi has anyone experienced a ecu sudenly go bad and causing the bike to run rich as f...?
My 2010 TE450 recently refused to start and fouled a plug. Put in a spareplug and was eventualy able to start the bike with a battery booster, the display now showed "fail" and i had to open the trottle to keep it running, and it was running extremely rich with black smoke and sore eyes. Been thru the most of it, intakeboot, tempsensor, etc. The bike had the Special parts ECU so as a last try i put the stock ecu in, idles like a charm and runs pretty fair. Need to reset the TPS but cable is on its way from Scott as we speak. Will hook up the other ecu to read fault codes to, but there will be a few as i have been unplugging different sensors in the troubleshooting.
Juvkam
Juvkam
