Baddrapp
I have done a little research. I have found the DS650 is the same as the single BMW F650. So if that is the case, ours is the same as the F650 but with performance parts; high compression piston, performance cam, etc.
The DS uses the twin spark plug head with four valves.
The point being the DS650 used carbs and not fuel injection. There are several manufacturers making stroker kits, carb manifolds, cams, crankshaft mods, just about everything. MSD makes a really nice spark control box with better coils and the box has ignition timing via dip switches.
The DS650 wiring harnesses are readilly available. My thinking is if the ecu become such a big problem, buy a used harnes as a starting point and eliminate all our electronics. Go with the msd ignition, lectron carbs, and when its time for a rebuild, go bigger.
