Ecu Replacement
Discussion in 'TR650' started by nycrider, Jan 3, 2016.
  1. nycrider Husqvarna
    Aprilia Dorsoduro 750, Suzuki DR650
    A while ago when installing autotune for powercommander I've made a massive mistake which I'm not proud of and possibly damaged the ECU. Instead of tapping into the taillight wire, I've tapped into the starter relay wire, resulting in the bike's idle rpm to fluctuate between 2500-4000rpms.
    Stuff that I ruled out:
    - TPS - I was strongly hoping this was going to be it, but after replacing the tps, same problem was still visible.
    - Idle Air Controller - It was a little bit dirty, cleaned it, no change.
    - O2 Sensor - Same problem persists with the stock sensor, w/ PC O2 sensor, w/o O2 sensor at all.
    I've called husky/ktm dealers in the 50 mile radius to see if any of them had the MOSS tool to track down the problem, unfortunetly, none of them had it. I've heard the bmw gs-911 tool is compatible with the tr650, so I called up a couple of bmw mechanics and was told that they use a different diagnostic tool at their shops. I'm guessing
    gs-911 mainly for consumer use and I don't really want to dish out $400 on something that I don't know how to use and I don't know if it'll help me at all. I've also tried contacting the "big boys" at husky and ktm to see if they could direct me to someone who can aid me with their bike, but the email conversation died down after giving them my information.
    After more online research, I found a person with a f650 dakar, whose bike displayed similar symptoms to mine. It turns out that his ECU was faulty:
    http://www.ukgser.com/forums/showthread.php/345744-HELP!-F650-GS-DAKAR-IDLE-PROBLEM
    And so this brings me to my questions. Has anyone needed to replace an ECU on their TR650? If so, do you only need to replace the ECU or the ECU along with the ignition and the keys? Its part number says "coded" so I'm guessing it can only be purchased through a dealer?
    Ongoing, could it be that the wiring harness is partially fried causing something to malfinction or be totally left out of the equation?
  2. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    I have an additional ECU from Husky when I raised the stalling issue and I have swapped it in and out twice when the MOSS Tool was working (you need the programming side to do it). But I cant do it anymore as the programming side does not work anymore. My suggestion is to get on-side with a BMW Motorrad dealer, their system should do it, but they have to want to help you.....
    Roger 04 RT and nycrider like this.
  3. hasenpfeffer Husqvarna
    CO
    Idle fluctuation could also be due to a leaking throttle body vacuum port. For instance, the port used for the charcoal canister may no longer be plugged effectively if a canisterectomy had been performed.
    nycrider and Mark_H like this.
  4. WayneC Husqvarna
    Sydney
    F650GS Dakar
    The 650GS problem you refer to is not relevant to the Terra, different ECU, different fault
    Re the starter relay wiring you tapped into, it depends on which wire you tapped into as to whether it will cause a problem
    If it was one of the red wires it will not cause a problem, they are simply +12v, if it was the Brown/Yellow wire it will likely generate error codes in the BMS-E but should not cause any further problems, Your fault will be some other problem, possibly even the PCV or leaking throttle body as suggested above
  5. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    I hope WayneC chimes in here. Not many people have the knowledge/diagnostic ability that he has and he's becoming more familiar with our Husky's.
    engineerk9 and nycrider like this.
  6. PaulC F class
    Bayside Brisbane, Australia
    TR Terra
  7. Geeza Husqvarna
    Sale, Victoria, Australia
    PaulC and nycrider like this.
  8. nycrider Husqvarna
    I have not performed cannisterectomy. Problem persists with/without PC installed.
    Would you by any chance would be interested in selling that spare ecu if I was able to send it out to husky to reprogram it?
  9. hasenpfeffer Husqvarna
    CO
    Note that a leaking throttle body vacuum port is still possible, even with factory emissions equipment. You could try removing the vacuum hose from the throttle body side of the charcoal canister control valve and plug it. The valve has been known to cause problems for some.
    Mark_H and nycrider like this.
  10. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    No sorry.
    nycrider likes this.
  11. Roger 04 RT Husqvarna
    TR650 (friend's)
    2004 BMW R1150RT
    Have you tried removing the PCV and returning your bike to stock?
    For the idle rpm to vary that much, either the throttle or idle stepper motors have to be adding air. I would try to figure out where the extra air is coming from.
    Is something making the throttle open a degree or two?
    Are the idle steppers moving?
    Can you cap the canister line?
  12. drzcharlie Husqvarna
  13. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    As I have said and advise... If and when the Terra ecu crappers out, I'm switching it over to a more usable setup... microsquirt.
    Close to $600 for the pc5 setup, and only a bit more for the MicroSquirt. Sure there will be some issues, I am not aware of anybody converting a TR650 at this time, so it is not going to be a plug and play install.
  14. WayneC Husqvarna
    Sydney
    F650GS Dakar
    It would be a hard road to swap out the BMSE, it would mean Dash replacement, ABS/Alarm removal where they ae fitted due to the use of CAN BUS
  15. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    The micro squirt is can bus compliant. It would only take a custom module to make it all work, but alot easier to just think of it as an upgrade vs swap out. Meaning getting a new dash as well. Our dashes are problematic anyway, and hard to read etc.
    I'm doing a trial on a new ecu... it comes with a different wrapper, and so far is promising.
    And shaft drive...suck it BMW.
    Johnn likes this.
  16. Baddrapp Husqvarna
    Yucca Valley
    TR650
    Monster fuel injection will build an ecu for our bikes. He needs all the sensor values and a rotating crank assembly. It would require a new dash assembly for the gauges.
  17. WayneC Husqvarna
    Sydney
    F650GS Dakar
    The monster devices on their web site indicate they are yet another snake oil salesman with an add on product
    All a very hard way to go for the simple task of updating firmware and learning to use diagnostics to reset the ECU when changes to components are made
  18. Baddrapp Husqvarna
    Yucca Valley
    TR650
    No they do custom ecu's. They also have a fueler also. But they do custom ecus for bikes, quads and sxs
