125-200cc Electrical issue - WR 125 09
Discussion in '2 Stroke' started by OmerG, Apr 28, 2015.
  1. OmerG Husqvarna
    WR125
    Hi all,
    My speedometer turns on and off every few seconds in any RPM. In addition, in the last ride, when reached to the end of RPM, engine stalled when I pressed the clutch and turned on immediately when clutch released. I think maybe the two are related and I have an electric issue.
    Any ideas?
    Thanks!
  2. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    did u use the rear brake? my bike had a broke wiring loom for the tail light- just undo it and try again...
  3. jeanjean Husqvarna
    Netherland
    WR 125
    IT175H
    To avoid this kind of problems, and because I don't need it, I removed everything excepted the ignition parts (1, 12, 13, 17).
    I add a kill switch on the green wire comnig from the CDI/coil unit.
    But I don't know if I should keep the resistor located under the tank on the yellow wire (the one shown on the left top of the diagram, code 8000H1017).
    Anybody knows?
    Regards,
    jeanjean
