Electrics - how to connect additional devices ?
Discussion in 'TR650' started by mario33, Mar 9, 2013.
  1. mario33 Husqvarna
    Warsaw, Poland
    I've seen it somewhere, posted by Scott I believe (Mr HighFive) but cant find it by searching.
    I'm planning to extend electrics of my bike to accomodate additional devices: power connector to GPS, power output via cig. lighter type plug and possibly additional LED lights.
    I dont like the idea to mess with connecting all of that directly to battery. I need simple and clean method to take my battery in and out. I think I need some kind of switch. Any ideas, guys ?
  2. Trapperj Husqvarna
    Knoxville TN
    Tr 650 Strada
    R1200 GS RALLY..KLR 650..Zrx 1200
    Either a fuse block..or PowerLet makes a gizmo called the Termin-8. Allows up to 8 farkles to be hooked up..it's small..easy to use and has a fused link. Revzilla has a video on the thing if you'll look. sorry..don't have a link...just google.
    I've used both...the fuse block is bigger and has individual fuses and most will allow switched or unswitched power. The unswitched is handy for charging your cell with the bike off...draws little from the battery. The Termin-8 does not have individual fuses ...but still pretty cool. Very easy to stuff in a small place.
  3. Wadejesu Husqvarna
    TR650
    HD, Ducati, Triumph, Aprilia
    Hide everything under windscreen, lots of room under there, keep battery area uncluttered like Mario says
  4. Highfive Husqvarna
    Husaberg FE390, BMW F800GS
  5. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    Tap into Horn supply
  6. Link Husqvarna
    Modesto, CA
    TR650
    Aprilia, Honda, HD
    I used the connection for my Battery tender (fused). I had some extra connectors, wired one into a 12V lighter outlet. It does come direct off the battery, so if I leave my bike for a few days, I do unplug the connection under the seat. Not a perfect solution, but it works. Plus was cheap! $12 for the outlet, already had the connectors.
