Hello, Finally got my Strada last mid Dec. Can someone confirm if what I have is the 58hp motor? Could not seem to match the chassis number against the manual. TIA. Cheers!
If you're in North America, highly probable it is a 58hp unit. My dealer mentioned that the Australian distributor imported 48hp bikes to satisfy LAMS licensing requirements and the dealer converted to 58hp units as required. Not sure about UK & Europe. If you remove the seat, twist the throttle to full and look through the gap to see the throttle body, a 48hp (35kW) cable bracket will not allow the butterfly to achieve maximum travel. There will be a gap between the cast stop on the throttle body & butterfly.
