250-500cc Engine knock
Discussion in '2 Stroke' started by 24valvecummins, Jun 10, 2015.
  1. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    I have 14 wr300 and it has a knock at higher rpm's. I ride alot of single track in 1st and 2nd gear so i wind out the gear pretty high sometimes, when i do i get a single "knock" sometimes. Its not a consistant knock like gear issue or bearings. the jetting is good a little on the rich side. I was thinking maybe something with the powervalve. Has anyone had this noise?
    thanks pat
  2. sned2502st Husqvarna
    2011 WR250
    If I dont have good fresh gas mine will knock under heavy load. Not race gas just fresh premium Shell pump gas. Stock bike and its a 250.
  3. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    I use premium fuel from quick chek, and its usually 3 weeks old
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I find the more i ride the more weird worrying noises i hear so far all it comes down to is 2strokes bash out strange noises had a detonation sound on high rpm's but i rev harder it disappeared anyhow it was piston slap so that whent when i canged the slug, 14plate bike i should hope the slugs good for a while longer yet tho.
    Keep an ear out for it if it gets worse start worrying otherwise go ride it.
  5. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    i hear ya i drive myself crazy with worrying about noises. Im guessing you ment plug when you said "slug" haha
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    No i ment slug piston is refered to as slug as its a slug of cast metal ;)
  7. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    oo i see!! my bad:thumbsup:
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    No bad its just another term wich some people use it my make a few more of posts understandable now.
  9. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Remove the reeds and look at the intake side of the piston. If the intake port has worn grooves on the rear piston skirt then it's time to change the piston before it breaks and screws everything up.
    juicypips likes this.
  10. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    I finally got time to look at my piston, and it looks good so I took my left side power valve cover off and looked at that. I will probably just ride it and enjoy.
    Petar and lankydoug like this.
  11. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    looks good!
  12. lankydoug Husqvarna
    MO
    WR
    TM 300en
    That looks about like mine did at about 200 hours. It's worth checking at least every year because once it starts to wear it will go fast. I think the 250s are much more reliable than the 300s in respect to piston wear on the intake side.
    24valvecummins likes this.
  13. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    thank you i will check it periodically as the hours go up:thumbsup:
