FE/FC Engine Oil in the Airbox
Discussion in '4st' started by Hicham, Jan 12, 2016.
  1. Hicham Husqvarna
    Morocco
    FC 450 2015
    Yamaha XT600
    Hi to All,
    Does it ever happen to some of you to see some engine oil in the air box. This oil caming through the hose going to the headcylinder cover ?
    Thanks.
  2. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    Not sure what the issue is, I have same bike and no oil issues. I did have radiator fluid run out the overflow during the first few hours on the bike. Seems to have stopped now that it is broken in.
  3. Benduro Husqvarna
    '16 fe501s
    KTM950sm, DR650, KLX400
    As an aside, Teambowles, I had the same thing happen on my bike with the radiator overflow and now it's stopped.
    As for oil in the airbox, that usually comes from the crankcase vent tube. If the crankcase is being pressurized enough to blow oil/oil vapor up into the airbox in any significant amount, it's because of "blow by", compression gasses escaping past worn rings.
  4. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    Did you fall??
    AndrewS likes this.
  5. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Usually it'll come thru in a tipover to on side or the other
