Excuse the dumb question here please I have an 06 610SM, and it has about 7300kms on it now, and loving every minute of it The engine oil replacement light came on today, now according to the manual this is only after the first 1000kms or so. Is this just a normal thing to come on every now and again to advise you to change the oil, or should it only come on that first time ? And is there a problem with it coming on again ? Cheers Chris
I believe the default is after every 30 hours of running, the oil can is displayed on the LCD. About 15 miles from home one day, I saw the oil can on the display. I thought I had just lost oil pressure, but later learned it was just a friendly reminder. I pulled over, checked oil level, checked for leaks, etc. I was pretty sure it was only a reminder, but imagine the cost of being wrong. I should have read that damn owner's manual. Instructions can be found here.
Thanks for that. Yeah i had a check of it when i got home, levels are all fine and looks good, glad it was just a reminder and nothing else, would not like to figure the cost if something went wrong. Will just reset it and wait for it to pop up again. Thanks again
