250-500cc Engine Rebuild Fun - What part is this and where does it go?
Discussion in '2 Stroke' started by dnietsche, Apr 12, 2013.
  1. dnietsche Husqvarna
    massachusetts
    Hello Everyone,
    Its time to play that fun game of where does this part go......See the Pics for the description.
    Any help would be very appreciated!
    Thanks - Dan
  2. colemanapp Husqvarna
    St. Louis, MO
    assuming you have a 250 or 300, it looks like part 19 in parts diagram for your HTS or power valve assembly. Check Halls Cycles website and look at the parts PDF. Thats where I got it from.
  3. Motosportz CH Sponsor
    It does look the the powervalve shaft collar. What bike? Also are you asking about the smaller part of the big washer as well?
  4. dnietsche Husqvarna
    massachusetts
    Thank you for all the help. I didn't take this engine apart so I don't have the memory on where things went. If you know where the washer goes that would be great also
    Thanks!
  5. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
  6. dnietsche Husqvarna
    massachusetts
    I have been looking the parts sheets over. I think it came out of the clutch somewhere.
  7. pvduke Husqvarna
    ... on the gas...
  8. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I would say it's either a transmission shim which goes on the end of the output shaft, or the shim washer that goes behind the needle bearings on the clutch or main shaft. It may have also come from the kick start shaft.
    Measure the ID and that should help narrow it down.
    MotoMarc36 likes this.
