125-200cc Engine swap 125 to 250
Discussion in '2 Stroke' started by Segadora, Jun 10, 2013.
  1. Segadora Husqvarna
    SM125
    Hello
    Is it possible to put a engine from a Husqvarna TE 250 (2004) on a 1995 Husqvarna WRE frame?
    Thanks
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    almost anything can be done but,,,,,,
    is the chain sprocket on the same side, will the radiators have enough surface for a 4t, you will need custom hoses, will the engine work in the current mount locations, will the cases fit at the swingarm interface
    look up some earlier stuff by Bill's MC as he was playing around with some combos
  3. Segadora Husqvarna
    SM125
    I will take a 250 bike and put all items on it to my frame.
  4. 2premo Husqvarna
    Northern NV
    sounds like a fun project, please take before and after pictures
  5. Segadora Husqvarna
    SM125
    What are links to bills mc?
  6. eahsalo Husqvarna
    Husqvarna SMS 2011
    If the chain is on the same side and you're willing to put effort into it, it's possible.
  7. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    I know the 98 and on 125 engine doesn't go into the 1995 125 frame as the power valve cover touches the frame and will not allow the later models motor to be bolted in. The 250 engine will also touch the underside of the tank.
    It would be a mission to make it fit and it would change the frame flex characteristics dramatically.
  8. Segadora Husqvarna
    SM125
    I choosed to buy a Suzuki DR-Z 400 SM instead
