engine swap ability wxc610 vs te610 vs...?
Discussion in 'Older Single cams' started by baldredhead, Jul 1, 2014.
  1. baldredhead Husqvarna
    610te
    Hi.
    I am new here and to husqvarnas, and haven't quite found what I am looking for with the search feature.
    The short version of this story is that I have a 1999 te610 that needs an engine, like it is totally gone not there at all. I want to get it running again because it would be fun and it is street plated, which is difficult to find here in California.
    Anyway, it is/was a right side chain, left kick bike.
    What motors will be the easiest to install?
    Locally there is a 1994 wxc610 for sale in my price range. From the pictures thebframe looks the same as mine?
    Are there smaller displacement huskies that also bolt in? 2 strokes even?
    Thanks for any help!
  2. photoguy_43420 Husqvarna
    Ohio
    11 Husqvarna's from 1973-2001
    73 Norton Commando 850
    I 'm sure a 94 610 motor would bolt right in. If you went the two stoke way take a look at 84-88 Swedish motors should also work as the frame is pretty close to the same. The only thing I'm not sure is on the Swedish two stokes is at the swing arm bolt not sure if it is the same. I have a 2000 TE 410 and I can tell you that the frame is same as the Sewdish 2stokes as I have several of them. As I said before not sure on the swing arm bolt never check to see if it is the same. If it was me I would go for a four stoke.
  3. baldredhead Husqvarna
    610te
    Thanks!
    I would certainly prefer a 4 stroke its just good to know what all my options arr
